Home > Technical > Mud flaps- snapped bolts
Bluestu36
Evening all!
I'm sanding down my crossmember to get it ready for painting, and whilst removing the rear mud flaps, the 3 bolts that connect the mudflap holder to the crossmember have snapped off.
I've tried drilling and I am getting nowhere.
Any ideas on what to do?
Also, are they self tappers or a nut an bolt and if so, how do you get to the nut?
Thanks in advance!
Stuart
Post #731159 25th Sep 2018 5:50pm
leeds
They will be rivnuts.on the inside of the crossmember.
If the rivnuts and broken bolt are spinning when you drill them out then you may well have to employ Mr Angry.
Brendan
Post #731168 25th Sep 2018 6:21pm
isacs
They are hexagonal shank rivnuts. So either carry on drilling or use a punch to hammer them into the member. Then you need to buy new 1's and a tool to fit them. Though there is a thread on a home made rivet tool somewhere
Greg
Post #731169 25th Sep 2018 6:22pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
^^^ If the heads have snapped off just use a punch to push them into the crossmember. You can retrieve the bits from inside if you have small hands. If the bolts are spinning, then cut off the heads -I used a Dremmel - and then push through.
I used normal aluminium rivnuts to fit the hole and the home made tool.
Post #731237 25th Sep 2018 8:38pm
zsd-puma
You don't need a 'tool'. just a suitably sized bolt with a matching nut and washer.
In the factory they just put the whole flap on complete with nutserts loosely on the bolts and buzz them up tight with an air wrench.
Post #731266 25th Sep 2018 10:54pm
Bluestu36
Thanks all!
ZSD-Puma - How do I tighten the nuts, as I can't get to them?
Post #731357 26th Sep 2018 3:58pm
isacs
Post #731384 26th Sep 2018 6:25pm
zsd-puma
Bluestu36 wrote:
Thanks all!
They're nutserts, use a nut and bolt screwed into it then tighten the nut against the nutsert that crimps it up the same as a tool does.
Either that or do what the factory do, put the bolts through the mudflap bracket screw the nutserts onto the bolts loosely, then push them into the holes while tightening them up, the bolts and brackets will pull crimp the nutserts up. Wink
Post #731393 26th Sep 2018 6:47pm
GoatRider
United Kingdom 2002 Defender 90 Td5 HT Bonatti Grey
TD5 90 Mud flaps swap. How hard can it be?
Sunday morning quick job on the Landy, or so I thought.
Just remove the front mud flaps and reinstate using new stainless steel brackets. One hour, tops.
(DeepCreep penetration oil and Kano Aerokroil Penetrating used all week in the build up to help loosen everything)
Four hours. Four Hours!!! and finally they are off after using every f*^^%ing tool:
Three socket sets.
Power impact driver
Wire brush.
More oil.
Ratchet spanners
Regular spanners.
Some swearing.
More oil.
Crow bar.
Lump hammer.
Lactic acid in the arms.
A big swear.
And finally the grinder. The final solution on a spinning captive nut. Now unusable.
I mean really. They are only mud flaps FFS!
Next week, the rears. Wish me luck.
Nick
Post #848827 9th Aug 2020 12:28pm
macfrank
Laughing And the wife wonders what the hell is he doing again... Wink Seems to have been easier to cut off the outrigger and weld it back on Laughing
I was lucky as our Defender came without front mud flaps and I didn't know LR used rivnuts. So I just used nuts and bolts. Involves some proktological skills, though...
Post #848853 9th Aug 2020 2:09pm
markb110
Re: TD5 90 Mud flaps swap. How hard can it be?
Three socket sets.
Power impact driver
Wire brush.
More oil.
Ratchet spanners
Regular spanners.
Some swearing.
More oil.
Crow bar.
Lump hammer.
A big swear.
Tip, when you replace the rear mud flaps, note the drain hole in the chassis that the mud flap bracket covers up. Drill a hole in the bracket to match.
Good luck
Thumbs Up
Post #848888 9th Aug 2020 5:17pm
GoatRider
Yes I spotted Land Rovers clever design trick to prevent my mud escaping the rear cross member. Although I've just sprayed my new ss brackets!! I'll now have to find a cutter to recreate the wide diameter drain hole. What's the best/ cheapest/one use hole cutter for stainless steel?
Post #848896 9th Aug 2020 6:06pm
markb110
I used a step drill bit, but that was on the original mud flap bracket and not stainless....
I also used a strip of adhesive backed neoprene to act as a barrier between the chassis and bracket to keep the metals apart.
Post #848908 9th Aug 2020 7:46pm
GoatRider
I was wondering about that and came up with just brushing on some waxoyl. It's definitely a moisture trap.
Right now, having just discovered rivnuts for the first time, I'm trying to find the right ones. I've ground and tapped out the existing and the hole fits my 9.5mm drill shank perfectly. Is that an M7 rivnut, the sellers online are a bit vague. Again, I'm going to go stainless.
Post #848911 9th Aug 2020 7:54pm
Pacha
They are originally M6. Rgds.
Chris
Post #848913 9th Aug 2020 7:59pm
