![]() | Home > Puma (Tdci) > Master clutch cylinder leak |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there,
Today I found some a small amount of oil (less than 0,5 cc) in the footstep down the clutch pedal. So, master cylinder should be leak. ![]() ![]() I think that some of you had the same problem and I have several questions: Can I drive safely for some time taking in account that there is not any trouble in change gears, etc.? After the leak start: How much time can take until the cylinder will stop to operate? Can be repaired or should be changed? I'm out of the warranty, so will be at my own cost ![]() Thanks! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
