Home > Td5 > Doubts on flushing coolant defender TD5 - help!!!
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi gents
I was about to to start flushing the td5 collant that have topped but not changed for 10 years. I have the following doubts
My model is a 2005 defender td5 and my doubts are generated from the work shop manual
1- the manual talks about a drain plug that I can’t find.
2- position heater temperature control to maximum hot position ???? What is this , is that doable ? Can I skip this as well ?
The photo below is from under the landy and it is all rubber without a visible drain plug ,
 Happy Travel
www.thegippo.wordpress.com
Post #730552 22nd Sep 2018 8:45pm
dorsetsmith
1- the manual talks about a drain plug that I can’t find. drain plug in low its hose under the rad have two land rover one has drain in this spot & one with no drain in place ( drain in place up too 2004 build post 04 drain omitted from hose) Arrow
2- position heater temperature control to maximum hot position ???? What is this , is that doable ? Can I skip this as well ? this control air flow hot and cold not coolant
Post #730554 22nd Sep 2018 8:57pm
jst
On the td5 the temp lever doesn't control how much coolant goes through the matrix so it doesn't matter where it is when you drain.
There is a fill point on top of rad hose, didn't know there was a drain plug. Just pull hose from bottom rad Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #730555 22nd Sep 2018 8:57pm
sherifsalem
Thank you very much gents for clarifying.
Mine Dorsetsmith doesnt have definitely the plug and ..... what was i thinking about the heater Smile got it has nothing really to do with the coolant Happy Travel
Post #730562 22nd Sep 2018 9:51pm
lightning
I just removed the bottom hose from the radiator although l didn’t get all the old coolant out that way. When l came to refill it l got in about two litres less than the manual said it should take.
Post #730570 22nd Sep 2018 10:41pm
You really want the lowest drain pipe pulled if you can at the lowest poing to avoid any residual fluid being left as that'll likely be fluid with detritus contained with in it. WeWillWin🇬🇧🇺🇸
Post #730572 22nd Sep 2018 10:43pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
When I flushed our Td5 two years ago, I was advised not to use the plug - which it didn't have anyway - but to disconnect the lower hose at the radiator. I suspended a plastic bag with a lower corner cut off to serve as a funnel.
Apparently the plugs have the tendency to break off, sometimes the whole plug assembly shears from the hose. You will still need the upper plug to let air out of the system, so you might want to make sure that you have at least a spare plug, there are also aftermarket aluminium ones available.
More important though: I didn't succeed to completely drain it, IIRC at least 5 liters remained in the block since I managed to add about only 8 liters until it was full. Even after a drive I couldn't add more, so I could't contribute it to the thermostat being closed.
Having flushed it meant that the remaining 5 liter was mostly water with no coolant in it, and since I already diluted the concentrate before filling, I had to drain some afterwards to be able to add concentrate to obtain the correct dilution.
There must be other ways to fully drain the Td5 block, someone told me to blow it all out, and I remember having read afterwards about removing a large plug from the side of the engine block to drain it, but unfortunately don't remember the details.A
Regards,
Joris
Post #730581 22nd Sep 2018 11:55pm
sherifsalem
Reading your experiences i understood that i should try the lowest point or hose to unclip so that i flush the maximum amount of coolant out
Again by doing so it does not guarantee that all the 13L would flush out need to keep this a possibility that this happens to me.
i assume it is not a good idea to use a radiator cleaner then if i cannot guarantee that all of the cleaner will be flushed out (better not)
I bought this liquid coolant already mixed on OAT technology, it says to use it directly without mixture,
it is writen 40% protection +110C - 25C.......do you think it is ok???
 Happy Travel
Post #730685 23rd Sep 2018 4:39pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
There is a engine block drain plug behind the alternator but the alternator has to be removed to do this, Otherwise remove hose from bottom of rad as already described Very Happy
Post #730688 23rd Sep 2018 5:17pm
4RF RDS
Seriously don’t waste your time, go to a shop and have it drained and vacuum pugrd on refill. Takes 10 minutes if the guy knows what he is doing. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #730689 23rd Sep 2018 5:18pm
geobloke
I don't think there is such a thing over here in the UK. Or at least I have never heard of it over here. Seen it in Canada though, that and drive through oil changes; which is genius IMHO...
Post #730691 23rd Sep 2018 5:21pm
4RF RDS
Well that bites Shocked I use the drive through oil chnagers but bring my own oil, filters and stuff and watch them like a hawk. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #730693 23rd Sep 2018 5:24pm
Vogler
Those are indeed my experiences.
I'm far from an expert, but you'll find the same qualifications on the technical sheet of Texaco Havoline XLC (ASTM D 3306, see https://cdn.opieoils.co.uk/pdfs/texaco/havoline-xlc.pdf ) and Castrol SF (ASTM D 3306, ASTM D4985, see https://cdn.opieoils.co.uk/pdfs/Castrol-radicool-sf.pdf) which are both LR recommended coolants.
I don't speak spanish, but the stuff you bought seems to be diluted already to the correct concentration.If you're stuck with pure water in the block, then you'll never manage to obtain the correct dilution.
I agree with the others that if you're not very keen on doing things yourself (I was Wink ) then you'll save yourself a lot of hassle by having it done
by a garage.
Greetings,
Joris
Post #730716 23rd Sep 2018 7:29pm
sherifsalem
I am more like you Vogler .......thanx mate looks like it is a good match indeed !!! i will skip the radiator cleaner and water to clean the circuit.
I bought the landy 15 years ago with the original coolant , always topped but never changed , saying that it went down to Morocco 4 times ....my coolant looks fine no leaks nor rust.
it should be an easy task going step by step and carefull Happy Travel
Post #730765 23rd Sep 2018 10:01pm
NickMc
Some older Td5 have the steel pipe with drain plug these are ok to removed- the type that the plug is in the rubber hose - don’t mess with it just pull the bottom hose off.
You’ll need to run the car up to temp and bleed the system. Td5s are not the easiest to bleed.
Seen a lot of people have funny cooling problems and most f the time it’s the oil cooler or water pump getting tired.
Post #730788 24th Sep 2018 1:12am
