Home > Maintenance & Modifications > Snapped crossmember bolt
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
Hi all,
I'm in the process of replacing the rear ladder on my 110 but have managed to snap one if the cross member bolts, any tips on how to extract the rest of it?
There is about 5mm of thread protruding past the bodywork if that helps!
Many thanks
Post #729758 18th Sep 2018 1:15pm
AndrewS
Drill it out 130's have feeling's as well you know Smile
Post #729761 18th Sep 2018 1:34pm
zsd-puma
which bolt exactly?
Post #729766 18th Sep 2018 2:01pm
TechnoTurkey
The cross member bolt at the bottom of the factory ladder.
Post #729769 18th Sep 2018 2:05pm
TechnoTurkey
Bolt as per this pic:
Post #729770 18th Sep 2018 2:06pm
Hufflepuff
If you soak it in penetrating fluid, you might find that 5mm is enough to grab on with using a set of good quality mole grips? 2005 Td5 90 XS
1989 V8 110 CSW
Post #729790 18th Sep 2018 4:02pm
AndrewS
Is this a bolt that goes into a captive nut that fixed onto the crossmember? if so:-
Option 1 file the remains flat, get a centre punch and punch the exact center of the bolt, drill a 5mm hole into the remains of the bolt. At this point you may be lucky and find that the drilling process may have weakened the bolt enough to unscrew it with some molegrips. If not then drill a bigger hole that matches the internal diameter of the thread of the bolt. Then tap the hole out to clean the existing thread in the captive nut.
Option 2 drill the bolt out over size and replace with a bolt over size. (if you can get your fingers in behind the crossmember)
Option 3 Drill the bolt out over size to suit a rivnut and fit a rivnut to match the existing.
Option 4 replace the chassis (PS i'll take your old one off your hands) Thumbs Up 130's have feeling's as well you know Smile
Post #729791 18th Sep 2018 4:07pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Climb underneath, clean the threads of the remainder of the Bolt with a wire brush, yes I know its awkward, use lots of penetrating oil, use mole grips on the broken head end to jiggle the remainder in and out, it you will probably be able to remove it. Best of luck. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #729794 18th Sep 2018 4:35pm
LR90XS2011
clean up the rear as previously suggested, then drill a hole the same size as the bolt in a bit of scrap strip steel, arc weld the strip to the bolt, unscrew using the strip, the heat from the welding will most likely release the bolt from the thread DEFENDER 90 TDCI XS,
Post #729797 18th Sep 2018 5:34pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
As above but you could use a nut instead of a metal strip. Remember to disconnect the battery before welding anything on the chassis to protect your electrical equipment. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #729798 18th Sep 2018 5:46pm
zsd-puma
Ok so the rear tub mounting bolt.
I think if you move the plastic shield in the back of the wheel arch you can get at the back of that bolt. so you can give it a good soaking with release fluid. Ordinary WD-40 or Diesel will do, but proper penetrating oil will be better. Halfords even do a WD-40 branded 'penetrating fluid'.
Once you've done that centre punch the middle of the bolt and drill into it, chances are the heat from drilling will be enough to free it off. 5mm is probably not quite enough to get a good grip on it with mole grips without them slipping and damaging paint.
Post #729807 18th Sep 2018 6:59pm
sako243
Puddle weld another nut on top. Whistle Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #729816 18th Sep 2018 7:20pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
You could also try the drilling options above using a left hand drill bit. It might just unscrew it at some point - if you are lucky.
Post #729830 18th Sep 2018 8:16pm
NickMc
You should be able to get at the back of that from the wheel arch.
Heat and vise grips - I don’t use drilling or extractors if I can avoid it.
You might be able to heat it and instead of spinning it out the bodywork side bring the clean threads out the back on through the hole if that makes sense?
You can also try and shock it with heat then cold water.
Post #729839 18th Sep 2018 8:55pm
zsd-puma
my concern with using heat on that is paintwork damage.
Post #729846 18th Sep 2018 9:30pm
