Home > Camping, Caravanning and Holidays > Roof tent |
Nakatanenga Cargo bear roof tent quick mounting system here
For the Peterborough LRO show I dropped a clanger and mouted a roof lodge exo tent so it opened over the passenger side. Only problem was also had a foxwing mounted on nearside! Ooops So undo 8 bolts (no skinned knuckles) rotate tent through 180 degrees and replace 8 bolts. Less then minutes for two of us. Brendan |
18th Sep 2018 8:04am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
I've decided our roof tent is easier clamped to bars so 6 easy to reach gutter bolts and you can lift the tent and bars off in one. Might not suit your needs though. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Sep 2018 9:14am |
Sancho Member Since: 28 Mar 2017 Location: Winchester Posts: 24 |
I've looked at this system, that Tuff-Tek sales but its pricey!
https://tuff-trek.com/sputnik-system.html |
25th Oct 2018 3:56pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8078 |
Just had a look, not really following from the description, from pics looks like your left with square on top of rack and whole tent sits higher? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Oct 2018 7:07pm |
Cargobear tent mounting system consists of two squares. One fixed to roof bars and an interlocking square to base of tent. Eight allen headed bolts lock the two squares together. Comes with a long allen key driver. Once squares are fitted it is literally just a few minutes to undo the bolts ready for lifting roof tent off. It does lift roof tent up about 40mm.
Brendan |
25th Oct 2018 7:20pm |
now i get it,. thanks Cheers
26th Oct 2018 8:54am |
