![]() | Home > Puma (Tdci) > Radiator Grill Removal |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
How do you take off the radiator grill? The workshop manual just says “remove six screws” but only shows four. Is it just that simple. Your advice please.
Merlin |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Essy
2 large screws either side towards the bottom,, open bonnet, and 2 small self tappers into the top panel California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
is the xs different from the flat fronts?????? i just have the 6 all up front and with no need to open the bonnet. |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Air con models have a different grill that sticks out more
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I have eight plastic buttons that seem to be pushed in (probally with a hammer).
Merlin |
Ah,, you want to take the grill off the actual surround then !! Yep, 7 or 8 plastic "raw" plug type push in retainers,, just push then back through from the inner side, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
