Home > Puma (Tdci) > Fluid loss ?
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Fluid loss ?
Have noticed a leak underneath vehicle, the two pipes that run above the gearbox are soaking wet oily, this has dripped on exhaust and down chassis, any ideas, fluid levels seem ok, diesel?
Post #67799 18th Apr 2011 2:48pm
MK
Check if it is oil (clear= gearbox, less clear=engine) or diesel. Sometimes an overfilled gearbox spits oil through the upper breather.
Fuel pipes run through the left side of the chassis and go over the Tbox. Puma 110" SW
Post #67846 18th Apr 2011 5:54pm
kingofthesparks
just had lr assist out , needs to go into dealer, transfer box oil seal failed Big Cry Big Cry Big Cry
Post #67849 18th Apr 2011 5:59pm
