Home > Tdi > Timing belt change cost - 300tdi
Gongladosh
United Kingdom 1989 Defender 90 300 Tdi CSW Arrow Red
Hi,
Does anyone know the going rate for a timing belt change for a 300tdi please?
Thanks!
Post #724238 19th Aug 2018 2:59pm
gilarion
circa £200.00 make sure you also replace the tensioner as well. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #724240 19th Aug 2018 3:16pm
Gongladosh
Cool thanks, is that garage or self fit?
Post #724243 19th Aug 2018 3:31pm
gilarion
Garage fit inc parts from an independent garage from a main JLR dealership you can triple that price For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #724245 19th Aug 2018 3:38pm
Gongladosh
Perfect, thanks!
Post #724252 19th Aug 2018 4:03pm
Procta
cost me about 350 for the belt change and that was with me supplying the parts. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #724674 21st Aug 2018 7:28pm
LiftedDisco
...also make sure you change the water pump P gasket at the same time otherwise it’s going to leak soon after it’s all back together...
Post #724699 21st Aug 2018 9:07pm
Phantom
‘P’ gasket?? you don’t touch anything to do with the water pump or gasket when swapping a 300 cambelt out, you only open up the timing chest so why would the p gasket leak??
Post #725518 26th Aug 2018 6:34pm
ickle
sods law......
Post #725531 26th Aug 2018 7:33pm
Phantom
Sod’s law......
You might as well change the fuel tank while your doing the cam belt, in case that starts to leak, maybe also the crank rear seal - you never know........ Rolling with laughter
Post #725533 26th Aug 2018 7:45pm
TimS
United Kingdom 1997 Defender 90 300 Tdi CSW Arles Blue
£350 for a belt change with no parts supplied. Blimey. Shocked
Post #727856 7th Sep 2018 10:57pm
Procta
TimS that was with me supplying parts! I wont go into how much I was charged for the daft jobs that needed to doing for to pass the MOT, on top of that. I am going to start to research a different land rover specialist put this way, and one of the lads at work got charged 500 quid plus for his brakes, from the same place. Even he wasn't happy on what he was charged, He nearly died when I told him my total bill! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #727857 7th Sep 2018 11:02pm
TimS
You and your mate are getting well ripped off.
Defenders are ridiculously easy to work on. Sure they can be a bit annoying as they are old, but they were designed to be fixed with minimum fuss and cost.
I would definitely not go there again. You can do most jobs including a complete brake disc/pad change with a basic Halfords tool kit, a gunson eazy bleed for £20 and a free PDF of the workshop manual. Parts are cheap too from a variety of suppliers online.
The only additional things you'd need to do the timing belt is a long breaker bar and a tool for the crank harmonic damper which are about £60 on ebay. Oh and a box to stand on! Very Happy
Tim
Post #727861 7th Sep 2018 11:10pm
Procta
Oh yeah I have been well ripped off! The thing is starting to Censored PAS fluid now from the steering arm, and it wasn't like that before it went in either. Rolling Eyes
My parents think they are the best like, and I think they are way too expensive. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #727864 7th Sep 2018 11:59pm
