Home > Maintenance & Modifications > Engineering project to reduce weight in a Puma 110 |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1432 |
Tell everyone you started with a Discovery 3, saved 900kg and achieved all your goals?
20th Aug 2018 10:05pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
One important factor to keep in mind is that the un-sprung weight of a Defender is atrocious.
What with long trailing/leading arms cast in steel, live rigid axles and the heavy duty (and pre-war) swivels up front. Add to that over-dimensioned after market wheel and tyre combinations making the legs on your already lightweight bodywork (soft-top) almost a quarter of the overall mass of the vehicle. Yes, i do have over dimensioned wheels and tyres on mine. If you make a Defender body lighter, you will reduce it´s (already limited) ability to dampen and control the imputs from road and off-road surfaces. The handling will get worse. Within reason, weight does not affect the economy or the top speed. It will improve acceleration and braking, but our Defenders are so far off the scale as far as those talents are concerned, I wouldn´t bother. You´d need to lose a 100 Kg to really feel a difference. Even in the realms of track day cars and off road buggies, the type of ancilary stripping (seats, trim, heater, radio, wiring, sound proofing) that needs to take place to make a worthwhile difference often ends with the vehicle being left in the garage and eventually sold because it can only excel in one discipline. Having said that, our 90 has two Recaros and a few extra bits of chequer pate and a snorkel, and in comparison to others i have driven feels extraordinarily lively and agile. It does however have the extremely stiff (and heavy) KONI HTR´s and can feel extremely pre-war on short frequency bumps. As Timo K mentioned, the economy is directly related to the lack of aerodynamics. And believe me, there is nothing you can do to a Defender to improve that. Due to the flat and squared off shape of front end (the radiuses are not big enough to help) driven at over 50 mph the vehicle punches a hole in the air about size of a dual wheeled Transit. 1.5 times the width and height of the actual body. Make sure the engine is delivering full power, breathes easily (intake and exhaust), keep the tyre size down (235, not the 255´s ). 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
24th Aug 2018 6:33pm |
Remove the roof, windscreen and doors. Then buy a toneau cover, a flying hat and some goggles. That's probably help a fair bit. |
24th Aug 2018 8:14pm |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 |
The ratio of unsprung to sprung weight is important. Big heavy wheels influence a heavy vehicle less than they do a light car. Also the context of the energy input into the suspension (governed by what you are driving over and the vehicle speed) and the handling characteristics you are trying to achieve are important. For example: in my Caterham relatively small changes in the unsprung weight (lighter rims and tyres) made a significant difference to the handling on fast driven B-roads. So much so that I had to adjust the damping to suit. A lighter wheel / tyre combination on my 110 would not have made a perceptible difference to driving the same road at normal Defender speeds. |
25th Aug 2018 10:43am |
