Home > Maintenance & Modifications > Cabin Air Filter - 2.2 PUMA
fatnold
Australia 2015 Defender 110 Puma 2.2 SW Fuji White
Has anyone installed some type of activated carbon pollen/ dust filter for the cabin air intake? (or does one exist as standard but just doesn't do anytihng?)
Post #723922 17th Aug 2018 2:52am
Bluest
I haven’t done yet, but my intention is to try before my next big trip. I’m going to try to make a “sock” out of fish tank filter media to fit over the grille on the wing top intake vent.It’ll be hidden by a snow cowl once in place. I don’t expect it will filter fine pollution and pollen but should help cut down on dust and should be washable if it gets clogged. I got the idea from those socks you can put on top of a safari snorkel. 2007 110 TDCi Station Wagon XS
Post #723940 17th Aug 2018 7:03am
You will also want in that case to make sure that the duct from the wing-top vent actually connects to the unit containing the fan motor on the bulkhead, since it is quite common for there to be a gap big enough to stick your fingers through at the joint.
There are several threads on the subject on the forum.
Post #723952 17th Aug 2018 8:25am
