Home > Puma (Tdci) > Bubbling paint? Rust? |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
screen clamps,mirror arms,window catches will be covered under the warranty but not the back box hanger.
ps check ya headlamp bezels 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
16th Apr 2011 2:25pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I had the hinges re-painted under warrantee. The rule is that corrosion must be from under the paint. When I complained to Marshalls of Cambridge that a piece of paint had fallen off, about 1cm x 2cm, leaving bare metal they just said no way. We had a few words but they wouldn’t fight my corner. So out with the Hammerite again.
Merlin |
16th Apr 2011 3:41pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Oh joy... didn't think about those. I can hardly wait to see what I find! The front bumper is really rusty on the interior, and laters of it are starting to peel away. Strange, as I thought that waxoyl would've protected it. Oh well... |
16th Apr 2011 6:07pm |
Paul55 on here got his bumper replaced with the same corrotion as yours 2.4 90 XS
17th Apr 2011 9:24am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Thanks Eutek - I think
Checked my windscreen clamps this afternoon, drivers side fine, passenger side bubbling up nicely. No problem with my mirror arms, yet ! The dealer can sort the clamps along with the headlamp bezels when it goes in for its two year service in June. Bob |
17th Apr 2011 5:12pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
WHen i sold mine, i noticed that my passengers hinge was as yours is but at the bottom.
WIndow Catch as yours and replaced Load tie downs, also similar - replaced Headlamps bezels replaced Mirror arms i always wiped with waxoyl (clear) when cleaning as i did with the rear cross member - kept it perfect. exhaust needs to be falling off to replace under warranty Mike |
17th Apr 2011 5:35pm |
110 Member Since: 07 Apr 2011 Location: Nottingham Posts: 43 |
Argh just chekec mine and there are worst than your and I had them done under warranty last summer, would they redo them now even though the warranty has finished?
Is there a solution to this? 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS, |
17th Apr 2011 7:40pm |
Stupid thought - would powder coating be better ?
Also, Croytec do replacement windscreen clamps but I think they are silver only and mine is Galway Green. Bob |
18th Apr 2011 7:17am |
powder coating is the best Bob,I've had a pair of bezzels done for when these go again 2.4 90 XS
18th Apr 2011 8:25am |
Thanks Grockle - I shall get a pair of clamps and gaskets ordered up today.
Bob |
18th Apr 2011 9:31am |
inthedesert Member Since: 07 Mar 2011 Location: ireland Posts: 19 |
I have some (mostly) surface rust on various bits; what should I expect the dealer to replace/repair and what should I treat? Apologies for the non technical descriptions.
The minor problems are the black bits, as in the bumper, folding steps, brackets and plates under the bonnet etc. The more worrying things, to me, are parts of the steering between the front wheels, the drive shaft thingme front and back. The bonnet hinge bracket attached under the windscreen and the bracket inside the bonnet to hold the bonnet open. These could be more serious looking at the long term. |
18th Apr 2011 11:57am |
Track Rods and Ball joints etc round the wheels are fine - propshafts are fine - more surface corrosion Mike
18th Apr 2011 5:00pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
What year is yours? |
18th Apr 2011 5:37pm |
it was registered in May 2008.
18th Apr 2011 6:19pm |
