Home > Maintenance & Modifications > Cable guides
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Cable guides
Hi All
What is everyone doing to get light wires from the roof rack into the engine bay? I don’t want a snorkel and really don’t want to drill any holes in the roof (leaks enough as it is🤣🤣). I’m sure I can remember seeing something that went down the screen pillars but can’t find it now. If drilling the roof is the best option that’s ok but what connectors/ plugs have you used?
Cheers👍 Life is one big adventure, that's why we have the vehicle for the journey.
Post #723010 12th Aug 2018 1:06pm
A marine grade cable gland is an option I have see but more typically used to the rear. (With the highest IP rating is best I.e. IP 68 upwards.)
I myself wouldn't like drilling anything too but if I had to choose the vertical rear roof section would be my choice and certainly not 'A' Pillar posts. WeWillWin🇬🇧🇺🇸
Post #723018 12th Aug 2018 1:49pm
ericvv
Post #723022 12th Aug 2018 2:19pm
Mr Baldylocks
Thanks guys👍 Life is one big adventure, that's why we have the vehicle for the journey.
Post #723140 12th Aug 2018 10:02pm
Harry.O
I got some little black cable tie attachments from screw fix. They have an adhesive pad on the back and a ring that the cable tie secures through. From memory they were less than a fiver for a big bag. The adhesive seems good so far. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #723185 13th Aug 2018 10:27am
zsd-puma
And running the wires through some flexible conduit would make them look tidier too.
Post #723199 13th Aug 2018 12:24pm
