Home > A-Plan Insurance > Thank you, A-Plan Thatcham!
The insurance "problem child" of my vehicle fleet is due for renewal, my historic mobile crane, and it has always been difficult to find anyone who will even quote for it.
Based on the positive feedback for A-Plan on this forum I gave the guys at Thatcham a call and they have not only sorted me out but actually made it seem easy! This for a 12-tonne, rear-wheel-steer, "special types" vehicle, about as oddball as you can get!
So well done and my thanks to A-Plan, and on the basis of the very pleasant experience I have had today I have no hesitation whatsoever in recommending them. Thumbs Up
Post #722708 10th Aug 2018 5:59pm
discomog
What, no pictures? Come on let's see it Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #722735 10th Aug 2018 7:56pm
Here you go....
Post #722767 10th Aug 2018 10:22pm
discomog
I recall they used to name their various models after precious stones. Just out of interest what model is it and what engine as they seemed to use just about everybody's diesel engine.
Nice toy Thumbs Up Defender 90XS SW
Morgan Plus 8
Post #722789 11th Aug 2018 8:32am
JOW240725
That is unusual! Shocked James
Instagram @suffolk_rovers
Post #722794 11th Aug 2018 8:51am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Now that makes engine removal a doddle Thumbs Up
Post #722804 11th Aug 2018 9:20am
It's an Iron Fairy VI, engine is a 5.2L BMC Newage type OEB diesel. Cracking little machine!
Post #722848 11th Aug 2018 1:48pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
What’s the lift rated at, Looks like it would lift most things! Razz
Just out of interest, Does it have to have a LOLER test? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #722874 11th Aug 2018 4:52pm
discomog
My understanding is that LOLAR 1998 only applies to work places and would not apply to lifting equipment which is being used privately. Defender 90XS SW
Morgan Plus 8
Post #722954 11th Aug 2018 10:05pm
A-Plan Insurance
Site Sponsor
Re: Thank you, A-Plan Thatcham!
Thank you blackwolf! Could you pm me your name and post code so I can pass on the thanks to the relevant team members?
Carlie Smile Howden Insurance - Specialist Vehicle
Call us on 01635 874646 for a quotation
Post #723187 13th Aug 2018 10:38am
Max lift is six tons with the hook 5' or less from the front of the crane. The jib extends to a max of 18' from front of crane at which the max lift is 1.1/4 tons. Max height of lift is 21'6" (max 3 tons) on main hook, or 26' (max 2.1/2 tons) on the searcher hook. The jib can slew 10' either side of the centreline of the crane, which clearly affects the max height of lift and max load.
If used commercially, the crane would come under LOLER and PUWER regs., etc, just like any other lifting equipment from jacks to tower cranes, engine hoists to telehandlers, etc. Similarly for any loose tackle used with the crane, such as shackles, chains, slings, ropes, eyebolts, etc. (In fact if you have a company Defender, I believe that the jack in the toolkit is subject to LOLER since it is company-provided lifting equipment).
Used privately by the owner, a crane is not subject to any particular regulations nor inspection regime, and you are quite at liberty to be incredibly stupid and kill yourself if you want to! Although technically I don't need to, I get all of my lifting equipment and inspected in accordance with LOLER by an accredited competent person, mainly for peace of mind.
The crane is road-legal under the Special Types regulations, under which it is actually classed as "Engineering Plant" (surprisingly it isn't actually a "Mobile Crane" due to the very precise definitions of the Special Types regs). Since it weighs around 12 tons, the driver requires a Class C licence. It has a top speed of around 10 mph, which with no suspension and rear wheel steering is quite fast enough! Also since it is "Engineering Plant" it is MoT (or rather HGV) test exempt, which is a good thing since driving it to the nearest test centre would take the better part of a day!
I have owned it for about 10 years now, and effectively am its second owner from delivery in 1961. It was new to a Royal Ordnance Factory where it spent its entire working life until being cast when the factory closed (which was quite interesting since it had to be officially decontaminated before sale to make sure that no traces of RDX or other explosive residues were present), and it has does fewer than 4500 miles from new. I bought it partly because I like old machinery, I had the opportunity, the price was right, and it seemed an interesting and unusual thing to own, and partly because I am (very slowly) restoring a much bigger and older crane which I also own, and I needed some means of lifting some of the larger parts of that.
Post #723192 13th Aug 2018 11:00am
ian series 1
Interesting Thumbs Up
I only ask, as 90% of our work fleet have to have a LOLER test, I am currently going through the inspection course so I can LOLER our own kit “in house”
The guy that’s doing the training did mention that the HSSE wanting it rolled out on to privately owned machines too,
But the policing will be too difficult, as to who declares ownership etc?
It sounds Just like a load more red tape, and meddling for HSSE at the end of the day,
Trying to stop ordinary folk going about their Business! roll: 80" 80" 86" 88" 90"
Post #723196 13th Aug 2018 11:49am
That is interesting and rather disturbing, and sadly all too typical of the appalling low calibre of current legislators.
You are probably aware that recently there have been significant changes in the HGV test regulations with the result that several categories of vehicle that were previously test-exempt are now no longer exempt, one category being mobile cranes.
The rationale behind that changes was that many Special Types vehicles which were exempt were actually based on normal lorry chassis, and therefore were eminently testable. However in a manner which has now become only too typical the regulations were so incompetently drafted that some vehicles which really are not sensibly testable now fall into the regs (a fact which is causing some anguish in historic military vehicle circles). Fortunately, although mobile cranes are no longer exempt, engineering plant still is, for now at least. Realistically if I had to MoT the Fairy I would have to low-loader it to the test centre. In practice it simply means it would have to be SORNed for ever.
Can you imagine turning up at your local HGV test centre in something like one of Aiscough's 1000 ton mobile cranes? Madness, and surely not what was intended!
If LOLER was extended to privately owned and operated kit it wouldn't bother me too much since I work to those standards anyway, but it would add to the cost. I can't really see it happening however since it would be virtually impossible to enforce. I wonder how long before an inspection of your car jack is included in the MoT, and safe operation of the jack is part of the driving test (now that would get a lot of drivers off the road)!
Post #723201 13th Aug 2018 12:26pm
ian series 1
Quote,
You are probably aware that recently there have been significant changes in the HGV test regulations?
Yes, one of our older HGV access platforms has fallen into this test category ( in effect it has always been classed as a mobile lift/crane) there seems to be so much to take in now,
Everything is forever changing, and not always for the better! Rolling Eyes
It must be so frustrating for the Classic military guys, when we see some of theses roll up at the shows, like Dorset it makes you appreciate how much they put into their hobby, the general public don’t see that side.
Your right about the car jacks! Laughing 80" 80" 86" 88" 90"
Post #723209 13th Aug 2018 1:16pm
