Home > Maintenance & Modifications > Wider wheel arches
blakey999
Wider wheel arches
Afternoon,
I’ve just put a set of 18” Twisted wheels on my 110 Utility, they look great, however i feel they’re a little wide at ET0. Ive looked at some aftermarket wheel arches and in my photos below can’t decide if the two photos show different arches or the same at a different angle.
I like the look of the Spectre ones but what are your opinions on cutting the truck to fit them. Is this going to de-value my vehicle?
Post #722491 9th Aug 2018 12:21pm
I think that mods that are very visible and very difficult to reverse certainly have the potential to devalue a vehicle.
How big a gap are you trying to bridge? ISTR that member X4SKP on here came up with a subtle way of extending his arches by 10-15mm, which may be worth searching out. Darren
Post #722492 9th Aug 2018 12:26pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I'd say they are the same arches.
I'm only guessing, but its a shame the fixing points pre-shaped into the arches arent picking up the holes from the factory standard arches 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #722501 9th Aug 2018 12:50pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
I would say they are different, the down the side view doesnt have a snorkel of course it could have been removed.
Also if you look at the top of the arch to the top of the wing radius the gap looks alot less on the down the side view.
might be the angle though Embarassed
What tyres are you running and what sort of gap are you trying to cover, do you have any photos of yours?
Post #722505 9th Aug 2018 1:07pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
They are different. Look at how far up the wing the arch comes on both pictures.
Post #722509 9th Aug 2018 1:45pm
X4SKP
Hello blakey999
I wasn't the first to do this but pleased with the result...NO Body Work alterations, (other than to Wheel Arch) Adds around 35mm (projection) to standard wheel arch (sold as 1-3/4'') Here's the link... (I imported mine...have seen them occasionally over here)
https://www.amazon.com/Pacer-Performance-5...sbs_auto_5
I also dispensed with the screw fixings and used small Stainless Steel bolts (round head) + Nylock Nuts + Nylon Washers
I also didn't use the wire insert as it wasn't needed, the standard Defender wheel arch 'sets' up the positioning well.
http://www.defender2.net/forum/topic28806.html
http://www.defender2.net/forum/topic36568.html
http://www.defender2.net/forum/topic5309.html
http://www.defender2.net/forum/topic31800.html
Just enough for my 'needs' also looks 'semi standard' with black trim elsewhere...
Good Luck... SKIP
Post #722512 9th Aug 2018 2:21pm
blakey999
Thanks for the replies, I don’t ‘need’ bigger ones it’s just I wonder if they will make the wheels look
more at home. Here are a few poor quality photos!
Post #722548 9th Aug 2018 5:28pm
mk1collector
They look fine Thumbs Up only thing wrong is the white lettering on the outside Whistle Rolling with laughter Ray
My build thread
Post #722563 9th Aug 2018 6:12pm
