Home > For Sale & Wanted > [For Sale] '92 200TDi Defender 90 for sale
Mr S1
Ad receipt number 180809-973
1992 ‘K’ plated Land Rover Defender 90 200TDi (currently on a private plate which does not form part of this sale and will be removed). Drives really well, anyone who has been behind the wheel says the same. Owned by me since October ’15 and I have literally spent a fortune getting it to where it is now, but circumstances have now changed and I ideally could do with the space so it’s time for all the hard work and money ploughed into it to benefit someone else !
This is fully equipped for off-roading but I have not had it offroad once (believe it or not !) which is a total waste, and given such little overall use it’s now in the way. Wears 33’ Kumho tyres (and still drives nicely as above) and has a brand new (and necessary) breather kit fitted for wading along with diff guards, rocksliders, front bash guard, tank guard etc. Literally ready to go. The entire underside has been professionally and fully Dinitrol’d by Underbody Protection to seal it, the chassis itself having had some welding done prior to me acquiring but is rock solid and now fully protected. Outriggers all solid, had one replaced when Dinitrol done so all 100%. Rear crossmember replaced before I bought, again 100% solid and also fully Dinitrol’d so won’t give any problems. Towbar fitted (Dixon & Bate ball and NATO) and full electrics (not once used !) MOT’d until Dec ’18, passed the last ticket with one advisory being a small blow on the exhaust – that’s it. Done very very little mileage since so no reason why the next MOT will be any different. Cosmetically looks OK, had a paint job again before I acquired which was more a blow over being honest and isn’t the greatest job but is presentable, driver’s door has a few dings but is far from battered and the passenger door could do with a bottom section but otherwise is solid. Bulkhead good, had a little spot of welding where it meets the screen but again otherwise solid. Tubular steel front winch bumper fitted which I think looks superb, always wanted to get a winch fitted but never got round to it but it’s ready to take one should the new owner wish to. KBX front grilleset fitted which is far better looking than the original Land Rover effort in my view, new headlamps that are bright (and work !), new indicator / stop light lenses, LED numberplate light, new indicator stalk (another Landy weak point and are prone to failure), gearbox rebuilt about 2k miles back as second gear went so had it fully overhauled with new clutch fitted. Usual transfer box leak but not pouring out by any means and works perfectly, gearbox dry. Raptor metal instrument binnacle and bracket fitted
– the list goes on….
• Genuine Defender 200TDi engine, c.167k miles
• On original chassis with serial number stamped at front (albeit hidden under Dinitrol but it is there and matches the logbook)
• Chequer plated bonnet and front wings
• Tubular steel winch bumper
• New Terrafirma RTC steering damper
• Diff guards, tank guard, front bashguard & rocksliders fitted
• Belt done 3k miles
• Gearbox rebuilt, new clutch fitted at same time
• Fully rebuilt genuine Adwest steering box – steering now tight as a drum along with new power steering pump
• New radiator / oil cooler fitted
• New Revotec electric fan kit fitted (genuine 200TDi fan cowling comes with car but not fitted, however fan blades still in place)
• Brand new Glyn Thomas full wading kit for diff’s, gearbox and transfer box venting to atmosphere via snorkel – no chance of them taking on any water
• Multiple security which will only be divulged to the new owner
• Professionally Dinitrol’d throughout including inside chassis
• New door and screen rubbers
• New lockset (ignition and petrol cap keys different)
• Momo streering wheel (smaller so more comfortable to drive with than the standard unwieldly dustbin sized article)
• Raptor metal instrument binnacle and bracket
• Carpets fitted on seatboxes and matching floormats
• Farm jack mounted in rear
• Thick rubber loadliner
• Genuine Land Rover rear mudflaps
• Dixon Bate towbar
• Rear step fitted
• Stereo fitted inside centre box
• Parrot BlueTooth fitted
I think £6,500 is fair for a Defender that’s literally on the button and ready to go with all the right bits fitted and presents reasonably well. At this money it’s very much comparable with others out there and is worth that. All the known issues are rectified, so this just needs using for what it’s been built for ! Bear in mind this is a 26 year old Landy so is not perfect by any means – if that’s what you want then you need to be spending £50k plus with the likes of the Chelsea Tractor Co or Twisted Smile
Any sensible questions, please feel free to PM me and I'll do my best to get to you ASAP.
Post #722486 9th Aug 2018 11:56am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
nice looking truck , seem a good price too Thumbs Up
Post #722554 9th Aug 2018 5:39pm
Mr S1
Thanks Smile
Post #722564 9th Aug 2018 6:20pm
Mr S1
Bump Smile
Post #724657 21st Aug 2018 6:37pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hi there,
A friend of mine is interested in buying a 90 for a bit of green laneing and last nite we were looking at your advert.
Do you want to drop me a PM with your contact details and we can go from there?
Where abouts Down South are you?
Many thanks. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #725581 27th Aug 2018 7:57am
Mr S1
Hi mate
PM sent
Post #725604 27th Aug 2018 9:09am
HK07
Many thanks. I have forwarded your details to him.
HK07 2007 90 Puma - Love it - Best car I have ever owned.
Post #725619 27th Aug 2018 11:24am
Mr S1
Bump....
Smile
Post #729962 19th Sep 2018 7:03pm
Mr S1
Still for sale, will put a new MOT on for the new owner. Get in touch if interested Smile
Post #734428 12th Oct 2018 9:11pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
its amazing no one wants this, i've got exactly the same Defender, best model they ever made
Post #734433 12th Oct 2018 9:45pm
Mr S1
Is it really this difficult to sell a Defender ?!
The few enquiries (not from here I add) I've had have been nothing but messers....
Thought these were selling like hot cakes, and I don't think I'm being unrealistic in my pricing either. The mind boggles.
Post #736713 25th Oct 2018 4:33pm
JOW240725
For me I think it may just be the look? It does look a little 'extreme off-roader' which may be putting people off? Personally, the LR decal and KBX grille are also off-putting. But easy changes so surprising people can't see past these. James
Instagram @suffolk_rovers
Post #736715 25th Oct 2018 4:41pm
Mr S1
Appreciate the feedback chap, thanks Wink
Post #736716 25th Oct 2018 4:42pm
JOW240725
But it does look a good solid well looked after vehicle, you just got to find the right person.
I've never struggled selling vehicles by just putting a For Sale sign and parked somewhere prominent (just make sure it's secure!).
Dare I say it's getting closer to Christmas so not the best time of year to sell. Have you tried any of the many Facebook pages? James
Post #736718 25th Oct 2018 4:46pm
Mr S1
Don't use Facebook at all chap - purposely - but appreciate the suggestion Smile
Graphics off is a job for the weekend, can't do any harm.
Post #736723 25th Oct 2018 5:25pm
