![]() | Home > Maintenance & Modifications > fitting an auto box in a td5 defender |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
David at Ashcroft transmisions is your man for this job,he may give you some advise.
He has done many many conversion for the landrover crew. He has also done the Auto conversion for the puma and i must say it drives very nice with the Compushift controler. Regards Pete |
KCS Member Since: 05 Sep 2008 Location: shropshire Posts: 18 ![]() ![]() ![]() |
thanks for that
![]() KCS |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
having just put an HP24 and tgv in my 90 i can confirm Dave is the man to speak to. they will supply parts only as well. plus they do a centre console to finish the job off properly Cheers
Thanks for that james, autobox on the backburner for now but i know where to go when its back on the agenda.
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Can you please confirm what a 'HP24' and 'tgv' are please, is this part of the Ashcroft Conversion? ![]() |
HP24 is an upgraded version of the HP22 which is the std 300tdi auto box (it has uprated oil pump and TC)
TGV = The 300 tdi made under the International Banner with 2.8L and VVT giving 135bhp and 375Nm Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for that is the HP24 the same Auto box Ashcroft are offering in the Puma, if so does it have similar gearing charateristics to the 6 speed we are used to. I would like to think that if I put an auto box in then I would be achieving similar RPM's to that of the 6 speed manual, espcially when in 6th cruising and in top on the Auto. ![]() Thanks Rich |
i expect its a version of the HP24 but i dont know have you tried ringing Dave? or PM him off here. Gear ratios have no idea, i cant see that rpm would be the same though unless they have a specific gear set for it which they may well have. mine is a 4 speed with lockup Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
