Home > Maintenance & Modifications > Fuel pump mod
Page 2 of 2 <12
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I'm currently also planning to install an electric fuel pump, the lift pump is leaking externally. I have a max 10psi Facet pump.
Is this pump's pressure low enough? The mechanical lift pump produces half as much but the Facet Dura Lift 4222 installed earlier in this thread produses more than the one I intend to install.
Basically what I want to know is what is the max pressure that can be safely fed into the injection pump.
Post #907648 13th Jun 2021 3:00pm
Page 2 of 2 <12
