Home > Off Topic > Yeah, c'mon, somebody start a garage thread |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17538 |
Your neighbours have evidently never seen a wolf in that case. He is exceptionally gorgeous! Last edited by blackwolf on 25th Sep 2019 7:33am. Edited 1 time in total |
24th Sep 2019 9:30pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1804 |
No we're too near the coast and civilisation for that! - but from a distance he does look remarkably similar to the wolves that get near my brothers house on the edge of the Carpathians. As with all things size is difficult to judge from a distance.
25th Sep 2019 6:44am |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 824 |
Hahaha cuddle dog. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
25th Sep 2019 7:12am |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 |
Here in NL space is pretty tight unless you live in the countryside or pay a lot of money for a property. Most houses don't have a garage and if they do, it is usually used for storage (bicycles, lawn mower etc) and hardly ever to keep a car in it, let alone have enough space to work on it. My garage is 2,9 x 5.8m, and when we had the house built we made sure the entrance would be wide and high enough for the 130 to fit. But as you probably already figured out: once the landy is inside, you can barely move around... Defender 130 HCPU Td5 MY2000
6th Oct 2019 5:57pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3786 |
I'm currently in the process of sorting the are for my new workshop / man cave /
I've had some trees taken down and now waiting for them to remove some stumps then, its flat pack my current single garage and sort the area read for concrete. The garage attached to the house will end up a room for the kids and this one at the back will be my area... So Knock this lot down, trees removed, mini digger in widen / lengthen, concrete base and then build.... Currently getting quotes for 6 meters wide by 11 Meters long. Maybe I should start a garage build thread. This is my start point. Click image to enlarge |
6th Oct 2019 6:11pm |
