Home > Td5 > Battery not charging warning light
Page 2 of 2 <12
excossack
jst wrote:
My aux will run my Engel in UK for 4 days no recharge.
IS the aux always fitted? Or left uncharged for prolonged periods?
Always fitted and charged via split charge relay (2 x 110ah) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #718910 21st Jul 2018 1:48pm
excossack
jst wrote:
Those reading are off main bat only?
Reconnect relay see if fault returns
Drop test aux
What's aux Voltage a day after being charged?
hard wire aux to main see what happens, this could drain main bat!
How old is aux. Whose setup is it? Vsr is What brand?
Two volt meters.
Volt meter 1 of main battery via cigarette power feed
Volt meter 2 of output of split charge relay - activated via a relay so only shows voltage when ignition on.
I did reconnect the switch wire to the relay and could hear the engine tone change and the relay click & battery light on. Unplugged and left unplugged and all OK. I took the view, the issue is relay, or aux batteries.
Drop test aux
No drop test available - will have to see auto spark
Normally good - can't recall exact figure. Currently at around 12.4/12.5v last I checked via voltage display on amateur radio wired to the aux battery feed
That was a test I was going to do to prove relay or not
Aux batteries 18-24months ish old. Relay is a 80amp continuous engaged by 12v feed from ignition. no VSR
Never had issues before. Had amateur radios, 3 other radios, LED lights, phone charging etc all working fine on rallies without issue. 1999 Defender TD5 110
Regards
John M0VAZ
Post #718911 21st Jul 2018 2:00pm
excossack
Checked main battery and getting 14.3v at idle.
Each aux battery is 12.26v each.
All connected up and aux batteries get 13.87v at idle.
Split charge relay re-connected and all appears well so far.
I was thinking, time to upgrade to something with more intelligence? Maybe a T-Max for example? 1999 Defender TD5 110
Regards
John M0VAZ
Post #719170 22nd Jul 2018 9:11pm
Page 2 of 2 <12
