![]() | Home > Td5 > Ignition switch broken |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello drinkdrinkdrop
Here you go... http://www.defender2.net/forum/topic56773....p;start=45 The X-Eng Barrel Lock will be an issue. I too have this fitted but in a non-standard form (PM me if you want to know more). Good Luck...simple cheap 'legacy' Lucas product...dubious quality, but there you are LR never improved this... Probably easier to fit on a TD5 with the non-puma shelf (as I remember it) but expect a few hours to complete...+ your approach to the X-Eng... ![]() Good Luck... ![]() https://www.defender2.net/forum/topic83242.html |
GoatRider Member Since: 09 Aug 2020 Location: Herts Bucks Posts: 16 ![]() ![]() ![]() |
Hi guys,
2002 TD5 90 So I'm fiddling around behind the instrument panel and accidentally touch the white ignition switch which just just detaches itself from the metal body, far too easily imho. I pressed it back on (not exactly easy access) but it didn't have a satisfying click. I'm convinced it could pop off. How are these supposed to fix? Is there a bolt or are the grey metal flanges that I can see designed to be click flanges and must somehow be worn? Grateful for advice. ![]() Click image to enlarge Man who run in front of car get tired. Man who run behind car get exhausted. |
It's just a spade connector similar to the one in the foreground. Slide back the white plastic sheath and tweak it a little tighter with a pair of needle nose pliers (I appreciate that this is easier said than done given its' location). I'd also disconnect the battery as it'd be easy to short something out whilst fiddling with wires in a confined space. Darren
Cheers Darren,
Is the spade connector behind the white cap? When the white cap popped off all I saw was what looked like a ring of flat copper contact points in a circle which looked like they must be the main ignition barrel contactors. I didn't notice see a a spade connector. I saw the grey metal outer locator flanges, 3 I think. Is the spade connector electrical or just a holding device. Mind you I didn't dare pull the hole thing right off in case something dropped out. Nick Man who run in front of car get tired. Man who run behind car get exhausted. |
Ah, I think I misunderstood your first description. It is a spade connector under the white cap but it sounds like the connector tab on the body of the switch has snapped off, which is a very different problem. It may be repairable with solder but more likely needs a new switch. Either way, it needs to come out.
It's fiddly but the switch can be removed from the end of the lock barrel and replaced without having to remove the barrel from the steering column. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
