Home > Td5 > Another Td5 not starting thread :-(
Page 2 of 2 <12
dorsetsmith
you can add anti-fungal anti-algae ingredients
1.5 bar of pressure. It should be 4 bar
had problem with one back Feb this year when towing up 1.4 hill no power checked fuel presser 2.1 bar started ok but not pulling power
removed the pump and fond bottom pump filter block with black gunk fitted new pump new lace life for engine pulling power back
Post #718566 19th Jul 2018 1:56pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Final conclusion: The new fuel pump has solved the problem, but its replacement highlighted that the fuel lines were brittle, so they were also renewed. There is no error code for low fuel pressure, so it needs to be diagnosed using a test meter via the fuel temperature sensor port on the fuel pressure regulator housing.
Thanks to everyone who provided advice.
Post #720477 30th Jul 2018 4:00pm
dorsetsmith
There is no error code for low fuel pressure, with TD5 engine fuel system has no fuel pressure sender fitted, good that its fix Thumbs Up
Post #720479 30th Jul 2018 4:06pm
Page 2 of 2 <12
