![]() | Home > Maintenance & Modifications > Fitting speedo healer to Td5 Defender |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 172 ![]() |
A quick search suggests that pin1 on the back of the speedo is the speed output to the ECU. Yellow/Pink wire.
Pin 13 on the Engine ECU (Black C0658) is linked to the instrument pack by via connector. Yellow/Pink wire. See: https://nas-row.com/index.php?threads/td5-...#post-7006 |
I would imagine that your speedo healer has 4 wires : positive, negative power feeds, a wire that goes 'in' for the speedo input, and one that comes 'out' for the altered speedo signal.
you need to connect the 'in' wire to the 'speedo' side of the yellow/pink wire, the 'out' to the ecu side of the same wire. I would probably suggest taking it back to your mechanic and getting them to change it for you... |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 222 ![]() ![]() ![]() |
This should be the information you need. The Speedo effectively doubles the pulse count coming from the Speedo transducer on the transfer box. Speedo transducer produces 4000 pulses per mile, Speedo then doubles that to 8000 pulses per mile which the ECU needs to see within a certain range depending on speed in order to use the cruise control. 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Pepsyseventy Member Since: 12 Dec 2024 Location: Bevaix Posts: 5 ![]() ![]() ![]() |
Ok top!! thanks |
Thanks all I will try to fix it!!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8169 ![]() ![]() ![]() |
Great explanation, thank you. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1144 ![]() ![]() ![]() |
Quick question: I you fit an overdrive, I suppose that relationship between expected RPM for MPH will also be messed up and so the solution would be to fit a speedohealer (or Nanocom correction) tuned for OD engaged since that would be to most used setting for Cruise Control to be operated? |
Yes that would work - I'd imagine that with some basic wiring you could only have the Speedohealer switched on when the overdrive is engaged, so you'd be able to use cruise control both with and without overdrive engaged.
There are some cheap Speedohealer alternatives available on eBay too: ![]() Click image to enlarge 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
That's correct, or in my case, a v8 5th gear ratio fitted to the recon gearbox which was sending pulse signals outside of the parameters that the ECU liked. CC would engage then disengage after 2 or 3 seconds. 6 years later and the little Speedohealer is still working perfectly, interestingly it has never needed resetting since installation, despite being left for months with a totally dead vehicle battery ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
