Home > Td5 > Roamerdrive shift linkage problem
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Hi Folks,
I'm almost done installing this Roamerdrive. However, I'm having issues with connecting the shift linkage with the lever. There's a couple wire conduits in the way. Does anyone have a solution,
Post #714632 27th Jun 2018 1:50am
4RF RDS
I ran mine under the wiring harness right beside the gearbox. You have to grab them and pull them away from the box. The shifter does still rub along the plastic cover so I added another wrap around it to be safe.
It works, its just tight. 👍. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #714777 27th Jun 2018 3:42pm
