Home > Puma (Tdci) > Air Conditioning Problem |
this post show under seat relays
http://www.defender2.net/forum/topic57192....t+fuse+box wiring diagram for 2.4 a/c system Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 26th Jun 2018 3:01pm. Edited 2 times in total |
26th Jun 2018 2:46pm |
The Bar Man Member Since: 22 Jun 2017 Location: Hampshire Posts: 3 |
Thanks, that's a great start and this evening's work taken care of.
I'll post an update when I've checked them out. |
26th Jun 2018 2:56pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
when they filled it did they pressure test it? i would suggest its leaked out and the compressor doesnt run due to this, ie to stop it overheating with no refrigerant in it. Cheers
26th Jun 2018 4:11pm |
The garage didn't actually do anything. They told me the refrigerant was fine but I don't know if they tested the level, pressure or both.
26th Jun 2018 4:17pm |
i would get the system pressure tested first before you run up the compressor and potentially kill it in the process. Cheers
26th Jun 2018 7:59pm |
They will have just checked the pressure, the only way to check the level is to vacuum it all out then refill it with the set amount of refrigerant and oil. Take it to Kwikfit and get them to recharge it, if it doesn't work they refund your money. Before they charge it they'll vacuum test it which checks for any leaks, the machine is automatic, if it detects a leak it won't refill it. From the Kwikfit site;
If it doesn't work after it's been refilled, then it could be the pressure switch is faulty. The compressor clutch won't engage if the pressure switch isn't activating it. AC systems are actually pretty basic. |
26th Jun 2018 10:52pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 737 |
If you've checked the relays for the system and it still won't work, check the magnetic coil on the compressor. Sometimes these die and you won't get cold air.
27th Jun 2018 2:27am |
27th Jun 2018 10:00am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
There are 2 fuses for the air con in the main fuse panel. I had the same problem and it was F42 that had blown. It now keeps blowing 2008 Defender 110 XS SW - M57N2 / 6HP28X
3rd Jun 2019 1:03pm |
Fixed it .. the wiring loom that comes from the bulkhead along the o/s front wing and to the fan had rubbed through the insulation and was shorting out on the sharp edge of the wing. Fixed the wiring and all fine now for the summer 2008 Defender 110 XS SW - M57N2 / 6HP28X
2nd Jul 2019 6:12pm |
