Home > Td5 > Transfer case - stripped threads - drain plug
excossack
The threads on the drain plug hole (transfer case side) have stripped.
I had a couple of thoughts on how to fix;
Drill and tap and replace drain plug with a slightly bigger size
Epoxy and bond the drain plug in place.
Buy a new TC from Ashcrofts with some upgrades.
Scream
So far I have managed to get the drain plug in and stay in, but not sure how long this will hold. A combo of copper washer and rubber washer to try.
I did consider removing the inspection cover and getting from the other side and replacing with a nut and bolt but I don't think there will be enough room but will have a look at the old transfer case in the shed and see what there is. The old one was considered, but needs new bearing on the front output shaft, rear output shaft leaks and jumps out of low box.
Bummer Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #713828 22nd Jun 2018 9:34am
rallysteve
John,
Halfords do these repair ones which might be a possibility?
http://www.halfords.com/motoring/car-parts...lug-hfx693
Not sure if there is enough room for the wings to fold out though. They do a couple of sizes i think.
Post #713831 22nd Jun 2018 9:44am
MartinK
^^ that's a great find rallysteve Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #713850 22nd Jun 2018 10:34am
jst
Recap to larger size Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #713861 22nd Jun 2018 12:15pm
excossack
That was a good find Steve, but on opening the spare transfer case there is not a lot of room between the drain and a big gear.
Drain plug seen poking out the side of the case
@JSt - Racap/rethread might have to be the order of the day 1999 Defender TD5 110
Regards
John M0VAZ
Post #713904 22nd Jun 2018 5:38pm
Pilgrimmick
Helicoil! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #713910 22nd Jun 2018 6:15pm
excossack
That might be the answer.. Not sure how you use them but maybe the answer. 1999 Defender TD5 110
Regards
John M0VAZ
Post #713925 22nd Jun 2018 8:14pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Go for a time sert, stronger and longer lasting than a helicoil 👍
Post #713927 22nd Jun 2018 8:18pm
excossack
Do these screw in, hammer in, drill in ? I assume once in, then you insert the drain plug(or replacement)? 1999 Defender TD5 110
Regards
John M0VAZ
Post #713934 22nd Jun 2018 8:37pm
williamthedog
Ok, it's probably best if you take it to a trustworthy garage, they shouldn't charge you that much. It saves you from the initial cost of the inserts and fitting kit Thumbs Up
Post #713940 22nd Jun 2018 8:56pm
excossack
I think that is my next move. My normal garage have a good bunch of lads. They get all sorts, classic e type, stags, etc right up-to modern day motor cars and my 110 Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #713945 22nd Jun 2018 9:40pm
excossack
Since I did the temporary fix the car has been fine. Discovered today a ring of oil on the floor under the transfer case.
Car is booked in Monday to get fixed and at the weekend I have a rally! Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #714520 26th Jun 2018 2:23pm
