Home > Puma (Tdci) > Which radio?
22900013A
Which radio?
I have been having a look though Landrovers spec spreadhseet for the 110 and I am confused.
It lists four options of radio set up, ie, none, cd and tweeters, then cd, tweeters and mp3 aux in two options, one at 430 quid, the other at 50ish.
We have specced the comfort pack which gives us the single slot cd and radio - question is, does this give the dash tweeters and the aux socket as well?
The vehicle is built on a base spec if that makes any odds.
Cheers. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #66552 7th Apr 2011 5:59pm
mse
I know the top spec set up comes with the AUX and Tweeters - it used to be clear...have you tried building on line? Mike
Post #66557 7th Apr 2011 6:26pm
JSG
Hi, I think the tweeters come with top range CD played with the aux input. John
2011 Tdci 110 CSW XS
Post #66568 7th Apr 2011 7:29pm
22900013A
Online build doesn't work for Defenders...pfft, I actually made Landrovers site crash, as well as noting a spelling mistake...ph well.
Its pretty clear there are two options, question is which one comes with the comfort pack? I'd kinda like to at least be able to plug in the MP3 player, me and the Mrs and music fans but not exactly into the mainstream radio stations... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #66569 7th Apr 2011 7:30pm
22900013A
All the radios options states comes with tweeters, however it is not mentioned on the comfort pack option spec. Its really the aux input I'm most interested in. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #66571 7th Apr 2011 7:32pm
22900013A
ENTERTAINMENT
Radio Preparation (including aerial, no speakers)
Single Slot CD & Radio & dash mounted tweeters
Single Slot CD & Radio including MP3/AUX & dash mounted tweeters
Comfort Pack - Convenience Pack, Single Slot CD & Radio
Thats what the spreadsheet shows. So as you can see, not very clear. Its not obvious which spec the comfort pack has. The full spec cd (430 quid) is an option on a base usw, the one without aux is also an option at 380. I would think the comfort pack must be at least the 380 option which would allow a 50 pound upgrade to aux spec? Thats how it seems to read to me? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #66575 7th Apr 2011 7:36pm
