![]() | Home > Puma (Tdci) > A little help please. |
salesman Member Since: 01 Sep 2014 Location: The Yorkshire Dales God's Country Posts: 72 ![]() ![]() ![]() |
Currently in Bulgaria, and I have a couple of weeping injector seals, which need sorting
Failed to cross the language barrier to explain what I needed so, It's a 2008 2.4 tdci. Does anyone have the part numbers for Ford replacement, copper washers, seals, and the bolts for the clamps, please. Cheers Barry |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Hope someone can help soon, I unfortunately can't. Might be worth trying Angry Pumas on facebook, you normally get a pretty quick response there.
Good luck! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Ford Transit Mk 7 2006-2014 Injector Seal + Washer Kit 2.2 & 2.4L Duratorq TDCi
Kit includes: 4x Injector Washers - 1378433 - 6C1Q-9M577-AB 4x Injector Cam Cover Grommets - 1372494 - 6C1Q-6K780-AB Copied the above from e-bay listing - https://www.ebay.co.uk/itm/Ford-Transit-Mk...2701895008 And the bolts - Manufacturer Part Number: 1673999 , 6C1Q-9T506-AC , 6C1Q9T506AC Again from an e-bay listing - https://www.ebay.co.uk/itm/GENUINE-FORD-TR...0005.m1851 Hope that helps ![]() |
Thank you very much, yes that will help,
Cheers |
