Home > Technical > Horn question
mk1collector
Horn question
Does anyone know if td5 defenders came with the wiring for twin horns? I think they should mount one behind each headlight but before I start trying to dig down to find the plug I wondered if anyone knew. Thumbs Up
Ray Ray
My build thread
Post #712204 13th Jun 2018 3:17pm
rallysteve
My 02' has wiring in place for twin horns (a 2way MQS connector if i recall). One is behind each front panel.
Post #712207 13th Jun 2018 3:45pm
mk1collector
That’s just what I wanted to here thanks Thumbs Up I’ll start digging Mr. Green Ray
My build thread
Post #712211 13th Jun 2018 4:08pm
jst
Confirmed, yes they should have wiring there Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #712212 13th Jun 2018 4:09pm
mk1collector
Post #712213 13th Jun 2018 4:11pm
mk1collector
Ok, another question. Does anyone know the wire colours for the o/s (drivers side uk) horn. I’ve had a good look and there are a pair of wires disappearing back up towards the wheel arch that are black and green/white. They are pretty stuck so if they are the correct wires I’ll drop the wheel arch cover Big Cry Ray
My build thread
Post #712247 13th Jun 2018 8:01pm
rallysteve
They are the side repeater wires, hence why they are resistant to coming out Laughing
I cant remember from memory but i think it is either purple/black or purple/brown. Should be down towards the headlamp 02' 110 TD5 Double Cab Rebuild Thread
Post #712264 13th Jun 2018 8:45pm
VVS210
i just got one of these... Very Happy
Post #712265 13th Jun 2018 9:08pm
sako243
Well I would start off on an I've got a bigger one but I know someone will better me. I've just mounted the twin trumpets inside my 110, just need to plumb in the air supply now. Doing a bit of a rearrangement so that the tank won't continually bleed out air via the Ashlockers.
Can get a photo tomorrow. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #712269 13th Jun 2018 9:35pm
mk1collector
There was another pair of wires going in the same direction that I’d convinced myself were the repeater wires but I’m usually wrong Rolling with laughter there were no other spare wires by the headlight so it must be one of the two pairs that went back towards the arch spat. I’ll have another look tomorrow Thumbs Up Ray
My build thread
Post #712274 13th Jun 2018 10:00pm
mk1collector
That looks fancy Mr. Green Ray
My build thread
Post #712275 13th Jun 2018 10:02pm
mk1collector
I was thinking of a train horn or a Tour de France horn but I’ve got a spare defender standard one in the garage so that will do for now. Ray
My build thread
Post #712277 13th Jun 2018 10:04pm
sako243
I have several but I keep killing them and they seem pathetic. What really took the biscuit was a police patrol car realising at the last minute he didn't want to be in the filter lane. Apparently a white 110 isn't big enough to see right next to him (I mean literally next to his door). Thankfully I managed to avoid a collision but from that moment started investigating better alternatives.
Then sourced a power steering relay box and pair of trumpets for the princely sum of £50 so a plan was hatched. Given I've already got an on board air setup (air con compressor style not weedy electric one) for the Ashlockers I don't think I'll struggle for air... Ed
Post #712278 13th Jun 2018 10:09pm
sako243
They're ******* loud (technical term there)
 Ed
Post #712557 15th Jun 2018 10:21pm
mk1collector
Post #712559 15th Jun 2018 10:37pm
