Home > Puma (Tdci) > Rattle on start / intermittent power loss |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17388 |
You're welcome!
I don't suppose you know how many clutches your vehicle has had since new? It is possible that it is still the original one in there, but the early ones were very inadequate. The good news is that the current driven plate is much, much, better and there are good aftermarket ones too. My '07 110 has done 225,000 miles and is (I think) on its 5th clutch, but I fitted it at 150,000 so it has lasted way longer than any previous one. It doesn't rattle but has lost its springiness and is due for a change. It's also about time to inspect and lubricate the dreaded output shaft (which amazingly is the original, and at 150k was a better fit with less slop than the brand new one I'd bought just in case)! |
7th Jun 2018 6:51pm |
Phid Member Since: 25 May 2018 Location: Dorset Posts: 85 |
No sorry I don’t know if this the first clutch or not. I will make sure the output shaft is checked when the box is out.
Cheers |
7th Jun 2018 8:43pm |
Rob90and110 Member Since: 06 Jul 2018 Location: Yorkshire Posts: 1 |
Is the "rattle" the EGR doing its clean up cycle on shutdown? 5 short sounds, thats normal. Just a thought.
6th Jul 2018 9:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Blackwolf - Purely out of curiosity when did you change your clutch? Mine was late 14’ it seems pretty good and runs better than the last.
The original lasted just 38k! Having said that I did learn to drive on it but didn’t go around burning the clutch. Regards the OP’s rattle, sounds possibly like a loose turbo heat shield or similar shield that rattles with vibration at its maximum. I.e. At start up and shut down. EGR makes a very specific cleaning cycle noise, and very little on start up. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
6th Jul 2018 10:29pm |
Checking my records, my Defender (new in 2007) has had replacement clutches in 2008 (10k miles), 2010 (60k miles), 2016 (150k miles), and needs another one now (225k miles). It is however still on the original output adaptor shaft!
The OP's rattle is the clutch, of that there is no doubt, and not heatshield nor EGR. |
6th Jul 2018 11:28pm |
