Home > Maintenance & Modifications > Oil in Handbrake DRum
molecatcher
United Kingdom 2004 Defender 90 Td5 HT Auto Arles Blue
Hi
I've got oil in handbrake drum. I know a seal needs replacing but can't find name or part number for it.
Any help gratefully received.
Thanks
Post #711013 5th Jun 2018 10:27pm
Can't help identify exact part but this maybe helpful:
https://www.landroverworkshop.com/ WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #711018 5th Jun 2018 10:37pm
dailysleaze
Here you go https://www.landroverworkshop.com/diagrams...ge_45155#7
It may also be worth replacing the flange too as that may be a cause, depending on age of your vehicle. Item 9 in the diagram
Another check worth doing, with the handbrake off (vehicle chocked) push the drum up and down to look for play. If there is, the bearing needs replacing too and is what will be wearing the seal out (item 4)
Post #711615 9th Jun 2018 6:06pm
