![]() | Home > Maintenance & Modifications > Gore products |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
Sorry, are you saying that you have Optimill hinges already and they're worn, or are you saying that your original OE hinges are worn and you were looking at Optimill as a possible replacement? I thought Optimill were reckoned to last forever. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
hence my lack of reply on how they actually do it. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I thought as much but seeing as it was asked a second time, it probably needed pointing out.
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
ive got the gore windscreen brackets and bonnet hinges, lovely products. Going to order the 110 door hinges, are they a sod to fit? and does it take ages to align the doors back up again?
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I have never fitted those hinges, however, if you take off and replace a door hinge one at a time you will have no problem with alignment. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
^^^ as just don one at a time, will take more time taking off the door card than it will doing the actual hinges in my experience. Cheers
Not when you've stuck ball bearings in the bolt heads, then it takes bloomin' ages!
