![]() | Home > Puma (Tdci) > Outside air temperature |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
You'll notice in the 2 pics above the LCD under the speedo is still visibly and LCD even when powered off. This isn't the case for the central one and I suspect this is because it isn't part of the pod on the Defender, just a blanking plate.
I suspect the OAT sensor would be part of the CANbus and so should communicate back to the instrument cluster potentially via the BCU or individually by itself. This begs the question what happens if you swap instrument pods with a Disco. Assuming all warning lights etc are the same ... anybody game to try that?? 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
I'd agree it seems unlikely the lcd is there
re
that would be the easiest way - unfortunately my mate's Disco is a compay car so he probably wouldn't be too keen on me cannibalising it - however if anyone has a spare instrument pod....... |
