![]() | Home > Td5 > Oil Leak |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
I had exactly the same leak, was clean looking diesel drips initially so I changed the fuel pressure regulator gaskets. The drips then just stayed oil coloured like yours.... traced it back to the back of the rocker cover so I changed that gasket. I hoped at that point the drips would stop but they haven't. However the car no longer drips on the floor it just always has a drip hanging there. I'm now thinking its possibly the back of the sump gasket? But I did recently change that when I checked my oil pump bolt, I'm just wondering if it didn't seat properly at the back. Either that or it's residual oil coming out of my saturated engine covers.
As above post, probably rocker cover.
I have the same problem, see attached link. http://www.defender2.net/forum/topic61512.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Sancho Member Since: 28 Mar 2017 Location: Winchester Posts: 24 ![]() ![]() ![]() |
I think it's pretty common to have a bit of weeping oil here around the join (see below for an image of my TD5 2006 taken last wkd) and I have replaced the gasket here after rebuilding my gearbox 4-5 years ago. But more concerning if you have a steady leak as mine doesn't really drip oil.
Have you checked the oil that leaking? Is it engine oil/gearbox oil? Or maybe even fuel with dirt in it? ![]() |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2945 ![]() ![]() |
Land Rover, oil leak. Kind of rolls off the tongue.
As in “I’ve got a Defender 110 Oil Leak” perhaps it should have been a model derivative. |
savory Member Since: 19 Sep 2019 Location: doncaster Posts: 1 ![]() ![]() ![]() |
had leakage on the drive for ages from sump area - eventually had it checked at local 4x4 garage and they informed me that the sump was perforated . At first I didn't believe it but they changed the sump and no leakage now.
2009 defender 90 ![]() |
jimmyvonk Member Since: 31 Aug 2017 Location: Melton Constable, Norfolk Posts: 34 ![]() ![]() ![]() |
Mine looked like that - oil was leaking from where the injector harness exits the head - the two O rings had gone flat - fitted new O rings and some silicone and (fingers crossed) all better. As it leaked out the fan blew it all down the side of the block etc.
