Home > Puma (Tdci) > Alarm 10As Puma 2.4 |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
That sounds like the action for when you've left a door open. The horn will sound twice and not activate the alarm.
If you open all the doors and then close them again does the interior light stay on or anything? |
17th May 2018 10:28am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6601 |
Agree with the above, it "hoots" and doesn't flash the lights when locked if it thinks a door is open. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th May 2018 10:39am |
lesende Member Since: 17 May 2018 Location: Galicia Posts: 9 |
thanks cupboard and Martin, the light stays on for 15 or 20 seconds and then it goes off if I connect the alarm it sounds twice and if I open a door the alarm sounds, that is to say if it connects the alarm and with the engine turned on the interior lights go off much faster
17th May 2018 11:22am |
The bonnet switch will also have the same effect I think. As the alarm will think the bonnet is open.
17th May 2018 3:22pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Have you tried a AS10 re-set? Sit in the car, arm, unlock, open the door and close. Merlin.
17th May 2018 4:43pm |
Solved. the bonnet switch failed. Does anyone know the reference to order the piece? and thank you all for your help
17th May 2018 7:45pm |
AMR2022. Well done for finding the problem 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th May 2018 10:08pm |
Thanks to all for the help
18th May 2018 8:42am |
