Home > Wheels & Tyres > Correct centre bore for defender alloys
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Hi what is the correct centre bore for defender alloys I have seen them go from 113mm to 117mm does this matter to much. Also what is minimum load rating for 110 alloys.
Thanks
Andy
Post #707248 15th May 2018 8:16am
UtilityTruck
I believe it’s 114mm centre bore 2014 Keswick Utility 2.2
Post #707294 15th May 2018 12:11pm
Cupboard
So long as the bore is at least big enough it doesn't matter. It doesn't use the bore to centre them or take any load so it's not critical.
As for wheel rating, the maximum rear axle rating of a 110 is 1980kg:
https://topix.landrover.jlrext.com/topix/s...d367/en_GB
So the absolute minimum rating for a wheel would be 990kg. A worst case scenario would be cross axled at full GVM so all the weight on one wheel but that's pretty unlikely. Obviously dynamic loading as you hit bumps would take that much higher and cornering will also put more load on the outside wheel.
Post #707488 16th May 2018 10:51am
Oakseywick
Thanks guys Thumbs Up very helpful.
Post #707552 16th May 2018 4:57pm
MadTom
Alloy wheels are centred by centre bore, steel wheels are centred by nuts. Alloys has only big through hole, not a tapper like steel wheels. The centre bore must be accurate. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #707564 16th May 2018 6:15pm
Cupboard
MadTom: ah, I didn't know that, thanks Smile
Sorry to have peddled incorrect information, I've only ever used steel wheels.
Post #707664 17th May 2018 9:24am
