Home > Maintenance & Modifications > Failed prop UJ.
Page 3 of 5 <12345>
๐Ÿ‘๐Ÿป No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #709016 24th May 2018 9:18pm
NickMc
Steve do you see now why I just buy the props made in India at ยฃ65 Mr. Green
Post #709023 24th May 2018 9:36pm
Oh yes, itโ€™s taken me so long due to not having various tools and sizes of sockets etc etc.
If it wasnโ€™t for that Iโ€™d have done it a lot sooner.
I could have bought a new genuine prop, but one slight problem with that was the front needs doing too.
Getting there at least. No Guts, No Glory.
Post #709030 24th May 2018 9:45pm
NickMc
You can never have enough tools Thumbs Up
Post #709033 24th May 2018 9:47pm
jst
always need tools, when you get into them its no more than an hours work. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #709081 25th May 2018 8:40am
I would have thought that a failed UJ provided the perfect opportunity to replace both propshafts with Gwyn Lewis HD ones, with a DC joint on the front one of course!
I have an MoT test on Tuesday and know I have a small split in a track rod balljoint rubber cover. Sine the rubber is not available as a separate part, as I see it I have no option but to fit SS Sumobars and a Disco drop arm conversion!
Post #709100 25th May 2018 10:58am
Blackwolf - I'll think about it one day. Funds don't allow at the moment especially with service coming up.
Just finished uo with it pretty much, that UJ loosened up with a bit of hammering and regressing again.
I would the prop ears were ever so slightly open compared to the other end.
So as far as I'm concerned all is well now and they all feel pretty equal.
I've just got the slider to degrease.
I know you shouldn't over do it and it feels pretty smooth so I'll just give it three pumps I think.
I'll post a bit more later, having a busy day generally!
Thumbs Up No Guts, No Glory.
Post #709142 25th May 2018 2:55pm
Well done Steve, good work !
Post #709152 25th May 2018 3:53pm
All done and all good. Thumbs Up A few pics and video I have I'll add later, short test run I've been on and everything see,s perfect, with no vibration, noises or gearstick wobbling about a lot. (Transmission being moved around by the b****rd UJ.)
Downside is, just popped down the road and the wipers failed. Thud Rolling Eyes
You'd never believe it, and 5 mins before I was due to be somewhere which I had to cancel.
So now I'll have to move onto that. Whistle
Gotta laugh though! Laughing
They stopped mid sweep, fuses seem fine Relay seems to click, no other noises or anything.
I'm guessing a replacement Relay, and wiper park switch would be a good start and cheapest start.
Also, what sort of puller would be needed for the spindles? I'm pretty sure they are on tight!
There were no odd noises, and no blown fuses so I'm thinking (hoping) it's not anything too much. No Guts, No Glory.
Post #709156 25th May 2018 4:41pm
Before dismantling the wiper system, try jiggling the arms. You may find one has locked up but can be freed by hand (they'll park spontaneously if the ignition is on, so be careful), in which case it is a sure sign that the wheelboxes and drive rack are worn.
Post #709174 25th May 2018 6:14pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Mine stopped working in the snow earlier this year. The rod that moves the wipers had broken at the motor. If you can hear the motor running then this might be the problem.
Mine is a TD5 so had to remove various bits but a simple fix.
Post #709176 25th May 2018 6:19pm
Blackwolf - Iโ€™ll give it a go tomorrow. Iโ€™ve bought a little puller for the wiper arms just in case I need it. It was only cheap so no concern.
Had enough for one day today though. ๐Ÿ‘๐Ÿป
One spindle has a little rust staining, Iโ€™ve noticed for a while but as there was no issue at all Id not investigated any further.
Is that a tell tale at all?
Paddle - Thank-you. Iโ€™ve got to investigate further but they were a bit sticky on the screen due to the weather. No Guts, No Glory.
Post #709179 25th May 2018 6:35pm
Blackwolf - Your suggestion worked. They are now working but as you mentioned is a sign they need looking at imminently.
At least Iโ€™m not stuck home still now.
๐Ÿ‘๐Ÿป๐Ÿ‘๐Ÿป๐Ÿ‘๐Ÿป๐Ÿ‘๐Ÿป Will be on here later and update thread. No Guts, No Glory.
Post #709186 25th May 2018 6:57pm
mk1collector
Pull the rubber cover back on the wiper spindle (just below the wiper arm) and spray some wd40 or acf50 down the wiper spindle then switch on the wiper and spray a bit more and they should free up. Don't forget to put the rubber cover back in place. Ray
My build thread
Post #709189 25th May 2018 7:17pm
jst
Series rubber TRE covers will fit and are available separately! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #709277 26th May 2018 9:25am
Page 3 of 5 <12345>
