Home > Technical > Flasher unit location??
Rosesofstone
United Kingdom 2006 Defender 90 Td5 CSW Tonga Green
Hi all
Just purchased a set of Wipac LED lights to fit to my 2006 TD5 Defender. Before fitting I need to replace the flasher unit with the newly supplied LED one. Can I hell as like find it? I thought it was located in the fuse box in front of the gearstick in the centre of the cab. Obviously not! Any advise would be greatly appreciated peeps!!
Bow down
Post #705523 5th May 2018 6:56pm
ericvv
Know it for a Puma, but not for Td5. But the flasher clicking sound is produced by the relay. So try to locate where that sound comes from and you should find the relay.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #705531 5th May 2018 7:30pm
mk1collector
Behind the dash clocks Thumbs Up Ray
My build thread
Post #705536 5th May 2018 7:44pm
bluebottle
Yep, behind the dash clock, but don’t bother putting the dash back on until you’ve done all the indicators as you need to be able to adjust the variable resistor. This will stop your trailer indicator light from coming on with every flash.
Post #706149 8th May 2018 11:08pm
Green&Gold
England 2004 Defender 90 Td5 XS CSW Willow Green
Wish I had read this earlier…. Sitting with the entire fuse box unscrewed looking for it.. thanks bluebottle Thumbs Up
Post #963082 27th Aug 2022 6:21pm
Procta
yeah its behind the dash clocks, its a black relay, but put the hazards and have a feel for a clicking relay Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #963840 3rd Sep 2022 1:46am
