Home > In Car Electronics > New RAM Phone Mount Fitted
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Fitted a new RAM mount this morning, no drilling required and seems to be rock solid and in just the right place for phone/satnav.
Post #705205 4th May 2018 11:54am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Thumbs Up
Post #705313 4th May 2018 9:12pm
Same location as I use mine.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #705325 4th May 2018 9:34pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #705392 5th May 2018 9:21am
HardCharger
Can you share the component numbers and more photos of your install?
I'm interested to do this for my phone and trying to figure out a better mounting option for my Garmin unit as the stupid suction cup thing that came with it now falls off at least once a day and it can get annoying especially if you're following it off road and it falls off!
Thanks in advance!
Post #705930 8th May 2018 4:59am
Scoobeenut
Hi HardCharger, I used the 1inch ball adapter with the 9mm hole in the base here https://www.mudstuff.co.uk/products/ram-mo...hball.html this fixes to the existing screw mounting at the top of the dash. Then just fit a phone holder or device mount here https://www.mudstuff.co.uk/products/ram-mo...older.html with the extension arm here https://www.mudstuff.co.uk/products/ram-mo...l-arm.html
No drilling required and I have run a charge cable up the dashboard from an existing usb connector from my head unit. Hope that helps. Slightly better picture of the dashboard fixing here
Post #705952 8th May 2018 8:43am
HardCharger
Many thanks, Scoobeenut!
Those help a lot!
Post #708019 19th May 2018 7:43am
Welshsurferdude
Wales
Just curious will the x grip fit a iPhone 8 Plus with a lifeproof case on its pretty chunky! too big for my trusty old Tesco phone holder! 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #708116 19th May 2018 8:36pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Mine takes the samsung 8 plus in an otter box.
Post #708136 19th May 2018 10:23pm
