Home > For Sale & Wanted > [For Sale] Standard Front Bumper
Page 2 of 2 <12
I've just done exactly that - galvanised standard bumper from Paddocks, T washed, primed and finished with satin black acrylic:
 Darren
Post #729330 16th Sep 2018 7:05pm
NickMc
Autoglym satin black spray paint is a pretty perfect match to Original if that helps anyone Thumbs Up
Post #729341 16th Sep 2018 7:20pm
johnnyd
T washed ? whats that.......I am assuming not washed with tea Rolling with laughter
I might go down this route
JD
 2008 TDCi 2.4 XS CSW
Post #729425 17th Sep 2018 7:14am
dorsetsmith
Mordant Solution T Wash Overview
For pretreatment of new galvanized steel where blasting or abrasion is not possible.
May be overcoated with a wide range of protective coating systems.
May be used to give adhesion of high temperature coatings to new galvanized steel.
Mordant Solution T Wash changes colour on application from blue to black to indicate the effectiveness of primary treatment.
tea back can be included Whistle
Post #729427 17th Sep 2018 7:26am
T wash, more formally known as Mordant solution, is a pre-treatment for galvanised metals that key it to take paint. Darren
Post #729428 17th Sep 2018 7:26am
johnnyd
Possible thinking about ordering this one? By the time I have added the t wash and primer and paint and fixing kit, this seems ok? Is it as good or near as good? This one includes a new fixing kit.
https://www.johncraddockltd.co.uk/land-rov...-with.html 2008 TDCi 2.4 XS CSW
Post #729456 17th Sep 2018 8:53am
It'll be ok. The three year rust warranty is something I haven't seen before. Note that it doesn't have holes with which to mount the rubber end caps. Darren
Post #729470 17th Sep 2018 9:34am
johnnyd
I'm guessing I can drill those myself if I decide to add the existing endocaps ? Or even glue them somehow. I will have to drill holes for the registration plate I guess, which is a shame......or glue that also? Is that legal?
JD 2008 TDCi 2.4 XS CSW
Post #729471 17th Sep 2018 9:38am
If you drill holes in it then you'll breach the coating and almost certainly void the warranty.
There's readily available foam tape for fixing number plates, which is what I've done for the one above. Darren
Post #729473 17th Sep 2018 9:43am
NickMc
Either the bearmach or all makes bumpers have the end caps holes in them I ant remember though. I buy ten at a time to make it worth t with the shipping.
Post #729560 17th Sep 2018 4:36pm
Mine's a Britpart one, complete with holes. Darren
Post #729565 17th Sep 2018 5:23pm
Page 2 of 2 <12
