![]() | Home > Technical > conversion to disc brakes |
Bert@E Member Since: 08 Jan 2016 Location: amsterdam Posts: 63 ![]() ![]() |
hello,
can i put a rear axle of a defender 300tdi under my 90 (1986) ? |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Yes, you can. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
with major changes?
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
No major changes as they are both coil sprung and have the same track. The 110 rear axle from a 300tdi will have the stronger Salisbury diff, should be the same ratio though, but worth checking.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Salisbury into a 90 needs the prop shortening by 1 3/4" (43mm ish) but as said, ends up quite short and prone to vibrations.
a 4 pin diff with HD shafts (or even a later Rover type 110 axle) will give similar strength to the salisbury, albiet without the weight carrying capacity. |
Wheel Member Since: 28 May 2014 Location: Essex Posts: 233 ![]() ![]() |
Sorry to hijack this thread Bert,
I have a 110 Salisbury axle that I was going to fit to my future 90 trayback for off roading. I knew I'd have to shorten a prop so was going to use a shortened Disco II front prop due to it being a double cardon which I thought would be better for vibration and articulation as it will be running a 5" lift. Can anyone offer any advice on this please, i.e. is this feasible and will it work as I'm now thinking the diff nose will be too long for a decent prop angle even with the double cardon ?? Thanks, Mark |
If you are going to build a trayback, why not put the axle a bit further to the back? Roel
voorfrank Member Since: 06 Feb 2017 Location: Schiedam Posts: 37 ![]() ![]() ![]() |
You can swap Land Rover axels from a Defender 90 and Range Rover and Discovery 1 without modifications
Only when you install a salesabury axel you have to shorten the propshaft. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1678 ![]() ![]() ![]() |
Unless it’s a 300 Tdi Discovery axle and you’ll need to change to the 4 bolt drive flange instead of the rubber doughnut style on the diff.
There is a brake pressure restrictor for the rear axle on the right chassis leg or am I mistaken? Are they the same for drum and disc brakes? Roel
