Home > Wheels & Tyres > Wheel hub bolt offset
Richmcgook
2005 Defender 90 2.5 TD CSW Zambezi Silver
Probably a common knowledge answer?
I have a 2005 defender 90 TD5, I would like to know the wheel hub bolt offset. When I have looked online there a various answers..
Post #701845 19th Apr 2018 1:47pm
What do you mean by "wheel hub bolt offset"? Do you mean pitch circle diameter?
If so, it is 165.1 mm.
If not, then I have no idea what you mean!
Post #701862 19th Apr 2018 3:00pm
Richmcgook
Hi Blackwolf, clearly I’m a novice, I want to change the alloy wheels but when I have been trolling through websites there are different codes ref the comparable models each alloy would fit, which I have been told this is the bolt offset? Or the distance between bolts.....help?
Post #701866 19th Apr 2018 3:40pm
Ah, ok. You need wheels with centre to fit 5 studs on 165.1mm PCD. This will ensure you can bolt them on.
You next choice is rim diameter, width and offset. Diameter and width are self-explanatory and the offset is a measure of the distance between the hub mounting face of the wheel and a vertical plane through the centre of the rim. Together these determine what size tyres you can fit.
Standard Landrover wheel are 16 inch diameter, around 6.5 inches wide, and have a +33mm offset, which means the centre of the rim is 33mm inboard of the mounting face.
There's quite a lot on the forum about choosing wheel sizes.
Good luck!
Post #701869 19th Apr 2018 3:51pm
