![]() | Home > Maintenance & Modifications > EGR Delete, yes or no, the on-going debate. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Removing any part designed to limit pollution is morally and in many cases legally wrong.
Sadly there are far too many in this country who believe that our laws don't apply to them. However it's not just individuals. Companies are selling illegal tuning products to customers either without informing them of their legality or as 'for offroad' with a nudge and a wink. I can see this ending soon though. Most likely an insurance assessor looking for a way out of paying for a claim. The drivers claim gets backed so they try to sue the tuning company... "Read the smallprint, 'offroad only'.." |
So far, i have planted around 1800 trees this year. Would that make it ok for me to dump a couple of tons of asbestos on your front lawn? |
Suggest you go dump it anywhere you want in Ukraine. That's what they do there, and matter of fact until today they still produce and use those miserable corrugated asbestos roofing plates there.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17700 ![]() ![]() ![]() |
You've just answered your own question! |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 564 ![]() ![]() ![]() |
I am a trained HGV mechanic and now work for a oil company inspecting engines for oil performance. personally I have removed EGR from my Td5, EGR is used as a inert material that cannot be burnt thus reducing the amount of oxygen in the cylinder, reducing cylinder temps. It is only used during certain engine conditions and won’t occur with a cold engine or at full throttle.
It reduces cylinder temps to reduce the amount of Nox being produced by the combustion process. It is a dirty way of reducing emissions as it can block EGR valves/coolers and also the inlet manifold and ports. Carbon which is the black stuff has a diamond like composition and can build up causing premature engine wear through worn rings and bore polish etc. On a Td5 you can get a performance benefit due to the restriction missing from the manifold but on all engines wear is less likely to occur Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Think you should by a fully electric Land Rover. ![]() ![]() No need to blank anything with those. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Just a blank cheque instead.
