![]() | Home > Puma (Tdci) > Remap now, add inter cooler later? |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Yes, IMO definitely. Solved the bowel problem, working on the consonants... |
annette Member Since: 24 Nov 2017 Location: Tilarán, Costa Rica Posts: 68 ![]() ![]() |
Yes, Pete's remaps are great.
Treat yourself to an EGR removal and modify the VGT tubo to a fixed geometry one.. And then do the remap. if there is anything left in the budget get the IIDtool. much more important than the intercooler. Say hello to Pete from the nutter in Costa Rica. Fixing Land Rovers in rural Guanacaste |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Had exactly this conversation with Pete from BAS. Get the remap now and intercooler later, was the crux of it. The remap will sense the lower temps automatically, nothing manual required.
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2692 ![]() ![]() |
Just to throw a spanner in your decision. I went the other way but only out of necessity. A couple of weeks out of warranty and my gen I/C split. So was forced to either fit a std gen or go aftermarket. So a call to BAS and a nice shiny I/C turned up with some nice hoses as well. And then when the slush fund had replenned itself I had a remap.
The I/C on it's own made no difference, or nothing that I could detect but with the remap it now pulls like a train 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1339 ![]() ![]() ![]() |
Not sure what level of mapping you are thinking about but I went for the BAS 150 remote option back in December. I didn't bother with the I/C upgrade.
The remap has made a massive difference to the way the Defender drives and I can recommend it 100%. I've also started using Millers Diesel Power Ecomax additive with each fill up of supermarket diesel. I think the engine runs quieter with the additive and does seem a little bit more responsive. My thinking is to replace the I/C if/when the original falls apart. From memory the insurance premium increase for the remap was less than £25 a year with Aviva, so no sting in the tail there. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
As I understand it, even with the BAS170 remap an intercooler isn't essential. However, as I wanted the remap for towing I was advised to have the uprated intercooler. Very pleased too!!
BAS offer upgrades at a small additional cost I believe, its on the website. Also worth speaking to forum sponsor Empire ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
I have the Alive 150 with standard IC.
I'm happy with it, but if I did go higher which I'm very unlikely to do so I would upgrade the IC. ![]() ⛽️🛢️⚙️🧰💪 |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Hmm .. I did remap first and then intercooler. Either I just drove too hard or because of the standard intercooler I let the exhaust temps get too high and ended up warping the face of the manifold and the manifold to turbo gasket started leaking. Having been through a few gaskets I ended up having to get it skimmed flat again.
On the positive side, I’m now very good at removing the turbo and refitting ![]() |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 ![]() ![]() ![]() |
Just had exactly the same. Check Engine Light and Limp Mode when joining the motorway on a Friday morning to go to a meeting. ![]() Couldn't get hold of an aftermarket cooler on Saturday but Pete & the team got one to me by Tuesday. No new software for me, I had to PX a kidney for the the cooler and hoses. Crazy to think you can blow the end tanks on the cooler with standard boost pressure. ![]() Click image to enlarge ![]() Click image to enlarge Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
So many manufacturers use combination plastic and aluminium intercoolers- but I find them hard to trust, you see so many of this type of failure. 2014 Keswick Utility 2.2
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
With my 300tdi I fitted an Alisport intercooler first - it made no real difference to drivability. Fuel pump optimisation a few weeks later (by a real expert) made a terrific difference.
My 2.4 tdci got a BAS remap when the EGR started to play up, so EGR delete, speed limiter removal and 160-165 bhp remap. 110 USW transformed. Added BAS intercooler and Naka thingy intake kit (I have a RAI fitted) 2 years later and there is some difference to performance. However in higher temperatures in Central Europe on Autobahns I feel more comfortable maintaining higher speeds for hours on end ![]() |
How strange ![]() ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
I’ve been thinking about getting the BAS2 RRC for my 90 2.4.
I’m intending to get one of the BAS I/Cs, the EGR blanked and decat the exhaust once I’ve saved up the pennies. My understand is (not sure if this is accurate), that the remap can be adjusted to optimise the engine for additional modifications at a later point. This won’t be for a while; I’m getting the chassis dinitrol-ed tomorrow (which is costing £520!) and need to replace the pinion seal on the rear diff. |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 ![]() ![]() ![]() |
My experience.....for what its worth.
I had my 2.4 USW remapped - DIY thro’ BAS after 165k miles - serviced myself (no history prior to me), but spoke to BAS prior to purchase and they were very helpful thro’ the purchase and install process. No intercooler change, no hoses, no filter upgrade but absolutely transformed the van (admittedly had a shabby EGR but resolved with the remap - and then some). I’ve just had the hoses, intercooler and filter upgraded through a third party on my replacement 2.2 (plus the BAS remap, also through the same third party) and just wasn’t happy with the result. At 40k miles it felt nothing like as good as the 2.4 with (by then) an extra 200k miles on it. But.....resolved and remapped over a couple of emails with BAS, plus the backup files, and there is no question it feels like a different vehicle (in the best way possible). Certainly everything I’d hoped for (above just the remap) and enough to make me consider saving for the turbo technics upgrade offered by BAS (don’t tell Mrs H). What I would say is speak to BAS. I had misgivings about my 2.4 on mileage and condition and had issues (with others) on my 2.2 but all resolved and certainly very happy with both. No affiliation at all but a good experience on two vans. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
