Home > Maintenance & Modifications > Lower sills fitting kit |
pepethekingprawn Member Since: 12 Jan 2016 Location: Lancashire Posts: 54 |
Genuine bolts are m6 galvanised flanged think 25 or 30mm, along with corresponding flanged lock nuts.
Whatever you use will get covered in all manner of muck so stainless may help if you were to ever remove them but it's debatable, just make sure you use plenty of assembly grease or corrosion inhibitor to reduce possibility of galvanic corrosion. |
7th Apr 2018 5:57pm |
