Home > Maintenance & Modifications > Alpine Window fitting |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
They are really stubborn to fit. I've done a couple of sets now (one was with holes I'd cut myself so was unsure if they were the right size, the other was when I resprayed a roof, so took t he factory ones out and refitted)
Both were just as awkward as each other. I think I just used copious amounts of washing up liquid and brute force. Fortunately the glass is quite tough so I didn't break any. |
1st Apr 2018 9:41am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2527 |
Have you tried the well tested method of using string around the seal? If you're unfamiliar with the method then type "Fitting a windscreen with string" into You Tube. Defender 90XS SW
1st Apr 2018 10:54am |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 173 |
Here’s a few pics of mine going in. The rubber was all perished on the old ones so I pulled them out cleaned it all up and fitted the new ones. It was a bit of a fight but the second side was easier! I used the orange twine you get on crabbing lines as it is thin, string and slippery to pull the rubber over the glass. I also remember the glass looked like it was sitting proud of the roof but with some brute force, I managed to push the glass back into the recess sufficiently. I would also highly recommend the special tool for fitting the infill rubbers and plenty of soapy water.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2002 Defender 110 CSW TD5 |
1st Apr 2018 8:28pm |
EuropeDefender Member Since: 02 Apr 2018 Location: Tuscany Posts: 11 |
I replaced my Alpine seals last sunday.
It was a really really complicated job. If I had not disassembled by myself the windows few minutes before, I would have thought that the glasses are wrong with my car. Now reading this thread I discover that there are seals for 4 and 5 mm glasses. May be my new seals were wrong... Si Vis Pacem Para Bellum |
8th Apr 2018 8:35pm |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
Anyone cut alpines I to a roof?
9th Apr 2018 3:36pm |
