Home > Technical > Whining/Groaning from Front when steering....
johnnyd
Morning All
Noticed of recent (last few months or so) that there is a moaning noise coming from the front of the4 truck when steering/turnng, is this indicative of a fault developing or just a normal 'feature' Reason for the post is I may need to drive 300 miles up toe Newcastle and obviously don't want to breakdown LoL
JD 2008 TDCi 2.4 XS CSW
Post #696213 26th Mar 2018 10:24am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
If you have power steering you can get a moaning noise, but only on full lock. You are advised not to maintain full lock due to the pressure in the PS pump. If you are getting moaning at other times when steering, then check the PS fluid level, but I would suspect a deteriorating pump.
I am certain others will provide more expert advice.
Post #696228 26th Mar 2018 11:01am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
If you get the noise on full lock, it's probably the tyre rubbing the radius arms.You can adjust this with the steering bolt. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696232 26th Mar 2018 11:18am
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
On mine it was the wife Rolling with laughter Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #696239 26th Mar 2018 11:43am
Tdi4
Srry pk1 there are no known fixes for this problem Rolling with laughter a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696243 26th Mar 2018 11:54am
johnnyd
It can be heard when stationary also, so I could rule the tyre rubbing out I think, It sounds from what is being said here its the power steering fluid or pump......Maybe.....Seems to be worse in reverse and near full lock, but that could be just a coincidence.....
Post #696253 26th Mar 2018 12:56pm
Tdi4
Try running the engine without belt and see if the noise disappears. It could be the power steering Or perhaps water pump. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696256 26th Mar 2018 1:07pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
is it this
http://www.defender2.net/forum/topic39086....+hydraulic
a groaning noise when tuning left when cold - if so, apparently normal and from resonance in hydraulic pipes - mine does this (MY2015)
Post #696355 26th Mar 2018 8:53pm
johnnyd
Turns out the fluid level was low due to a small leak in the steering box, garage topped it up for free and will replace the steering box for about 250 quid next month when it’s due for MOT and service.......
Post #696578 27th Mar 2018 8:20pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Was it only on full lock or all the time Rolling with laughter
Post #696701 28th Mar 2018 11:07am
