Home > Puma (Tdci) > Rattling Fold Up Seats |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Aren't there rubber pads set into the metalwork under the windows to stop this happening? I'm sure I've seen something like this on mine.
Pete |
23rd Mar 2011 11:04pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
i think this may be normal (well, at least mine also does it). i normally leave my seats folded down (the back-rests folded down) to avoid this "clack" everytime i go over a bump, etc.
when i'm out in the bush it's no problem because my fridge and food draws fit quite snug and prevent the folded up chairs from flopping around... cheers www.ralton.co.za |
24th Mar 2011 5:20am |
considp Member Since: 22 Mar 2011 Location: Medway Posts: 5 |
I think there are pads, but on closer look, it seems the whole plastic lining is creaking, taking the pad with it, so nothing to resist the wobbly chair.
Blanket stuffed down the side seems the only technical solution! |
24th Mar 2011 12:22pm |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
Mine do the same,they are comming out soon anyway to make more space in the back.The middle row seats also get play in them eventually and need constant fiddling with. Puma 110 SW
90 V8 SOFT TOP |
25th Mar 2011 4:28am |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
One of mine has just started - more of an annoying creaky-squeak at the moment, and fixed with old coat for the time being. 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
31st Mar 2011 4:40pm |
I have removed mine as they had little use.It's amaizing how much space is freed up. Puma 110 SW
90 V8 SOFT TOP |
31st Mar 2011 5:08pm |
