Home > Td5 > ECU
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
ECU
Want to get a spare ECU for my buggy, are defender and disco ECU'S the same? everything for sale seems to be for a disco
Post #64639 21st Mar 2011 10:00pm
NO, they're different.
Although a disco ECU will work on a defender, and vica~versa, you get lots of errors, and the temparature guage reads back to front.
Post #64716 22nd Mar 2011 3:15pm
bell-auto-services
Depending on what ecu you have fitted as standard some of the disco ecus can be converted.
Do you have a standard part number from your ecu ?
Pete
Post #64718 22nd Mar 2011 5:03pm
Pete, could you list up what the associated ECU's are that can be converted please?
Do you mean that a later flashable type defender can be fitted with a (converted) disco one?
What sort of £££ is it to convert a disco ECU? does it become a flashable defender typen then? trying to find a defender ECU at a decent price is nigh on impossible!
Post #64719 22nd Mar 2011 5:19pm
bell-auto-services
NNN000120 def/dis manual
NNN500020 def/dis manual
NNN500030 dis auto
NNN000130 dis auto
NNN000250 dis manual.
All above flashable. MSB?????? non flash part numbers are a different deal, though i can convert.
Pete
Post #64720 22nd Mar 2011 5:29pm
so, all the above can be converted into defender spec?
Post #64729 22nd Mar 2011 6:50pm
sc70
Pete
Cheers for help will contact you soon with part no's motor is away at the moment.
the ecu that came with the doner car was d2 auto which has now had a new ashcroft auto box, engine has been rewired to a defender loom. At the moment have 3 ecu's two d2 auto's 1 nnn 1 msb and a defender ecu i have borrowed to run car
Post #64734 22nd Mar 2011 7:33pm
bell-auto-services
Yes with exepction of the ????30 and 000250, though can be made to work but its more complex to get correct.
Pete
Post #64759 22nd Mar 2011 8:41pm
