Home > Maintenance & Modifications > Equipe Roof Console
Stef M
Belgium 2009 Defender 110 Puma 2.4 DCPU Stornoway Grey
Equipe Roof Console
Did anyone already install one of these?
Is it hard to do?
What electrics do I have to struggle with to get power to the roof console for my CB and the lamp in the console?
Or can i take the wire which is there already for the original lamp?
a lot of questions, I know... Neutral
Post #64595 21st Mar 2011 6:58pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I have recently bought a roof console ... the outback one ... it should be the same ...
for the lamp you can use the existing wiring...for the CB I've brought the wiring that came with the radio over the roof lining, down through the pillar next to the driver's seat and it's there, waiting for me to have a bright idea to route the wiring in to the battery ... the conection to the battery itself will be done by a professional ... I just do the dirty work! Mr. Green
when the work is finished I'll post pics ... won't be able to finish it this weekend ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #64655 21st Mar 2011 11:31pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
I recently installed a console Corsetti
http://davidecorsetti.files.wordpress.com/...-radio.jpg
Equipe is like that, but it costs less
The work is not easy !!!!!
You must remove the front cover of the roof
In the center of the roof there is a metal reinforcement ;you must remove it(It is welded to the roof)
Cut the cover of the roof is great as the console
For the lamp you can use the existing wiring, for the CB I've brought the wiring that came over the roof lining, down through the pillar next to the right seat .
The CB antenna goes under the roof lining, from the console to the rear door .
I did not install the radio
Sorry, I haven't photos
Post #64662 22nd Mar 2011 12:52am
ibexman
console
I have one of the lrs consoles made by equipe although not fitted yet interior roof ribs do not have to be removed accordingig to equipe instructions ????? cheers chris
Post #64682 22nd Mar 2011 8:48am
Theater
I have a Defender 90....
....Also in the instructions of the Corsetti's Consolle is not written to remove the central roof reinforcement...
Remove the lining of the roof and try to mount the console
....I didn't understand how to do it , then I called Corsetti and they told me that I should remove the central roof reinforcement Big Cry
Try to call Equipe 4x4 (+39 02 33514438 ) or write an email to info ( info@equipe4x4.com )
Post #64722 22nd Mar 2011 5:53pm
