Home > Maintenance & Modifications > Boomslang Loom replacement relay
Benmatt912
United Kingdom 2001 Defender 90 Td5 HT Coniston Green
Hi all, I’ve check the forum and don’t think anyone else has asked the same question yet.
I’ve had a Boomslang loom fitted for a couple of years and it’s been brilliant, fit and forget, until this week when I noticed that the dipped headlights didn’t always come on when I tried to turn them on. After replacing the switch I checked the earth connections on the loom, which were fine, and then checked the relays. One of the relays looked like it had been on the sea bed for a couple of years. I swapped the relays over and the dipped headlights worked, but not the full beams.
So now I am trying, and so far failing, to find a replacement relay. It’s a H4458-12VDC. Does anyone have any suggestions as to where to get one from?
Thanks, Ben
Post #692604 11th Mar 2018 3:27pm
That looks like a standard 30amp changeover relay. I don't think the 'H4458' is useful here, as it appears on both 4 and 5 pin relays.
 Darren
Post #692613 11th Mar 2018 3:59pm
dorsetsmith
HELLA 007794311 12V 20/40 Amp SPDT RES Relay with Weatherproof Bracket by HELLA
Post #692617 11th Mar 2018 4:07pm
Benmatt912
Here is a picture of the diagram on the current relays, interestingly one is 4 pin and the other is 5 pin and only 4 of the pins are used.
Post #692622 11th Mar 2018 4:14pm
Benmatt912
Sorted
Hi all, I’ve manage to get it sorted.
Thanks to LandRoverAnorak and dorsetsmith for there help.
In case anyone else in the future gets the same problem this is what I ordered:Standard relay change over 40 30 Amp 5pin R2032C-1
https://www.electricalcarservices.com/stan...OcQAvD_BwE
They seem to work so far.
Ben
Post #693316 14th Mar 2018 5:10pm
